Vacuum hose on the Turbo Control Actuator
Old Feb 17, 2002 | 05:53 PM
c00lduke's Avatar
Does anyone have any suggestion on how to get to these. I can't seem to with the crossmember in the way.
Thanks
~Luke
Old Feb 17, 2002 | 05:56 PM
Brede's Avatar
Pull out the engine! That's what I did. Made things much easier!
Old Feb 17, 2002 | 08:29 PM
If you are talking about one of the two actuators bolted directly to the front turbo...
I got to them from the top. Take out the airbox, and you should be good. It is difficult, but doable. You might have to push the coolant hose out of the way to get to them a bit easier.
Later,
Patrick
Old Feb 17, 2002 | 08:36 PM
c00lduke's Avatar
its the ones on the bottom of the turbos
Old Feb 18, 2002 | 01:00 AM
neevosh's Avatar
The Dude Abides
Jack the front of the car up and remove the front wheel. It's a PITA to get to unless you're directly under it.
Old Feb 18, 2002 | 11:41 AM
spooledUP7's Avatar
There and back again
I was able to get to them by simply jacking up the front. They are a bear to get loose though.
Old Feb 18, 2002 | 11:54 AM
spooledUP7's Avatar
sYnth.
Aug 19, 2015 06:27 PM
pzr2
Aug 15, 2015 08:29 PM
