View Poll Results: How common are those number in conjuction with the modifications i have preformed
common
30.77%
impressive
38.46%
get the fuck outta my face!!!
15.38%
i dunno
15.38%
Voters: 13. You may not vote on this poll
so i dynoed my car......
Old Jun 1, 2006 | 11:38 AM
--MAstermind--'s Avatar
i dynoed MY 88 Turbo II RX-7 recently shes got 130K and 92-95 compression on all faces both rotors turbo has NO shaftplay at all......all i have done is this:
(Custom side exit exhuast 2.5inch(is helps control the boost from boostcreep since im poor.....(its coming off since all the ricer SRT-4 guys use it sounds amazing though....and i have decided to get 3 inch open strait back...)
ported waste gate(just to outside of the stock flapper)
hitting about 9.5-10lbs
ported&semi poslished the turbo exhust ports
strait tube intake W/MAF (still in the works is the aluminum enclosed airbox)
also all emissions removed...and blocked (i fabbed up blockoff plates out of aluminum)
Super AFC (5 ****) with Pen & paper tuning i did myself....
mazdaspeed pressureplate
RB clutch
BLOWN suspention (KYB's on the way!!!!! GOTTA SAVE FOR THE GC's!!!)
completely gutted(obviously also NOT a power adder)
Greddy type S dump valve(obviously NOT a power mod)
Tahts it....essentialy i got ALL the after market parts used and i havent acually dumped money into her.....the exhust cost me 40 bucks its cheap and holds up great i needed it side exit restrive so i can control my boost and it keeps me right where i want to be...before i had the open cat......and it would creep to 12 & 13 i dont have the fuel mods for that yet...hence the restrictive exhuast....
plans...keep her running as is...finish the suspent
and finally here is the sheet
Old Jun 1, 2006 | 11:49 AM
Whizbang's Avatar
Respecognize!
for being sorta "duct tape tuned" id says that pretty good.
Old Jun 1, 2006 | 11:52 AM
ddub's Avatar
i am legendary
Looks like you're running kind of lean from 5k to 6.5k, ~13AFR's isn't the best for a turbo car running 10 lbs of boost...
I didn't see any fuel mods, not the best idea. At 10psi I'd hope to see you running at least a better fuel pump.
Old Jun 1, 2006 | 11:55 AM
i concur.....it runs great and strong but duct tape tune is a nifty way to put it...here is what she looks like (i have changed the wheels around..and am running 225....on 16x7's...they bow out more than id like them to....again duct tape tuning....lol....
Old Jun 1, 2006 | 12:10 PM
yes i want to get a fuel pump at least because i want to redo all the fuel lines to steelbraided and AN fit the fuel rails and convert the fuel system the way its on Fc3spro...jsut want to do everything all at once...right now im installing the FD diff and fabbing the airbox...so it can look clean in the engine bay....
Old Jun 2, 2006 | 06:51 PM
adrock3217's Avatar
Boost in..Apex seals out.
239rwhp is ******* GREAT for being self-tuned, and only at 10psi!
Old Jun 2, 2006 | 09:05 PM
ddub's Avatar
i am legendary
It's not great if it wont last... Having ~13 A/F ratios from ~5k to 6.5k isn't exactly a good idea with boost.
Old Aug 3, 2006 | 05:37 PM
i have ran it this way for about 1 year...lol compression on piston tester....~115 both rotor
Old Aug 3, 2006 | 05:50 PM
bacek's Avatar
fuel pump and youll be fine with your afrs
Old Aug 3, 2006 | 06:03 PM
ddub's Avatar
i am legendary
Ok so you've gotten lucky so far, do you really want to continue to risk it?
Old Aug 4, 2006 | 07:25 AM
well its ok i got an Rtek and msd digital 6 plus and im still waiting on injectors...im going to keep it safe..but NOW shoot for 280whp on stock turbo......im do a little more polishing and porting and tune the Rtek on a dyno....i hope i can brake that mark.....has anyone else? whats the most power out of a barely stock s4 recorded??
Old Aug 4, 2006 | 08:57 AM
jkimbro's Avatar
resU deretsigeR
The most power out of a "barely stock s4"? WTF kinda question is that?
Old Aug 5, 2006 | 01:53 PM
Turblown's Avatar
Turn up the boost
Defineatly can be done running it lean..
Just keep the intake charge cool.
Old Aug 7, 2006 | 12:08 PM
what do you mean, what do i mean?....as in an S4 ht-18 on a stock unported s4 block....with obvious fuel,intake,exhuast mods (or not gunna go anywhere anyways..)
what are some peoples whp numbers running on 14psi?
Old Aug 7, 2006 | 04:43 PM
umi415's Avatar
I ran 10 -15 psi (unported wastegate) on an open intake & exaust with walbro fp, fpr, SAFC-2, act pp & clutch rteck stock ports but didn't take it to the dyno. I expected more or less your whp numbers but decided to play it safe. Opened the motor ported rebuild the engine ( housings and irons were ok thank god) getting bigger injectors and a bigger turbo with I won't install untill a have the supporting mods tu run it. anyways great numbers but don't run it like that for long or you might regret it.
Old Aug 8, 2006 | 01:28 AM
ericgrau's Avatar
Clean.
Ditto. If you run too lean you'll be lucky for a while with no effect. Then it'll knock and you'll kiss your seals and engine goodbye. Most likely when the intake air gets hot.
Old Aug 8, 2006 | 11:27 AM
jkimbro's Avatar
resU deretsigeR
Barely stock, was the main thing I was trying to figure out. A "barely stock s4" was the phrase you used. What does this mean? Is j-rat running a "barely stock s4"? His motor/ports are stock....and that's about it. So, is that barely stock?
The original question just didn't make any sense.
Now, keeping the stock turbo, and stock ports on the motor (which is what it looks like you're asking now) I'd say MAX whp will be around 250-260 which will last for just a handfull of dyno runs before the turbo dies.
Old Aug 8, 2006 | 11:40 AM
260eh...shoot....well thats fine my Td06 will make a good replacement if my turbo goes...(and hopefully that will be all that goes..)....lol well ill have another set of dyno runs.....next week or so on 14psi....lol WITH a walbro and some injectors...(stock injectors and pump will destroy me im sure of it!)
Old Aug 8, 2006 | 06:18 PM
jacobcartmill's Avatar
just dont care.
you're making alot of power because its about to blow up.
Old Aug 13, 2006 | 09:56 AM
im kickin it down a notch now....ima take it to the dyno and tune it with the Rtek get some 720's and a walbro and ill post back up what i put down once again IN A SAFER enviornment for my engine instead of 13....lol
Rotate86
May 18, 2018 02:44 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
