Old 05-30-06, 04:28 PM   #1
gxl90rx7
breaking stuff
gxl90rx7's Avatar
Send a message via AIM to gxl90rx7 Send a message via Yahoo to gxl90rx7
What is the maximum injector p/w?
In the logs, it can show injector p/w in milliseconds. How do you convert the injector p/w (in ms) to a duty cycle %? Im assuming the p/w number is the injector "on" time. I just want to know what is the value where your injectors maxed out. Thanks!
1988 RX-7 TII 10AE BNR Stage 3, Haltech E6k
S5 TII OEM sideskirts replica group buy:
gxl90rx7 is offline   Reply With Quote
Old 05-31-06, 01:38 AM   #2
turbo2ltr
http://www.rx7club.com/showthread.ph...+cycle+formula
Future version of the logger will have an option to display D/C instead of PW. Actually I thought it was there already, but I looked and it's not.
turbo2ltr is offline   Reply With Quote
Old 05-31-06, 10:06 AM   #3
gxl90rx7
breaking stuff
gxl90rx7's Avatar
thanks for the link
so if i understand correctly, the injector pwm signal changes frequency with engine rpm? so the formula would be:
Max injector ON time (ms) =120000/RPM
the max injector duty cycle for rtek is about 60% (correct me if im wrong), so at 4000 rpm, your injectors will be maxed out at a p/w of 18ms? ([120000/4000]*.6)
Old 05-31-06, 12:35 PM   #4
HAILERS
HAILERS
Buy a meter with a Duty Cycle function. Backprobe a primary injector. Observe the reading in percent and ms. Done. Easy and requires no brain strain. Even RS sells meters with duty cycle. By a Fluke though.
HAILERS is offline   Reply With Quote
Old 05-31-06, 08:28 PM   #5
turbo2ltr
Calculating the max open time at 4000 RPM
Code:
ms = (1 / (RPM/60) ) * 1000
   = (1 / (4000/60) ) * 1000
   = (1/66.667) * 1000
   = .015 * 1000
   = 15 ms total possible open time.
Note the order of calculations. This was not properly expressed in the other thread.
So if at 4000 RPM you were at 10ms inj PW, and we already calculated the max at 4000 is 15ms
Code:
D/C = (PW/max open time) * 100.
    = (10/15) * 100
    = 66% D/C
Rtek max DC is near 90% but that has nothing to do with any of these calculations other than if your D/C ended up being close to 90%, then you know it's time for bigger injectors.
Edit: I corrected the math as per Henrik
Old 06-01-06, 02:09 AM   #6
Henrik
That thread is not correct. For a rotary, one rotor face goes through an
intake cycle per rev of the eccentric shaft. So the intake phase is
1 / (rpm / 60) * 1000 ms in duration. ie at 6000rpm, the intake phase
is 10ms in duration.
Duty cycle is then simply the commanded injection time / time available
at that rpm.
-Henrik
Henrik is offline   Reply With Quote
Old 06-01-06, 09:25 AM   #7
gxl90rx7
breaking stuff
gxl90rx7's Avatar
so i think i got it figured out:
DC = (PW*RPM)/60000
DC= injector duty cycle (decimal)
PW = injector "ON" pulse width (ms)
but from what ive read on the forums, the max duty cycle is around 60% for the stock ecu? The pocketlogger site says they only raised the injector cap by 5%? So how could it be 90%, or is it a misprint on the website?
thanks for the help!
Old 06-02-06, 12:55 AM   #8
Henrik
The "stock ECU only drives the injectors to 60%" is a myth. The stock ECU
will drive the injectors to ~85%, which is why the cap is only raised by
the 5%.
-Henrik
Old 06-02-06, 11:10 AM   #9
gxl90rx7
breaking stuff
gxl90rx7's Avatar
ah, sweet, thanks for the info!
