Would these fit? SF-Challenges
Old May 24, 2006 | 01:43 AM
HardHitter's Avatar
Front = 19x8.5, offset +34
Rear = 19x9.5, offset +40
Those +34 seems pretty low for the front. +40 will fit in the rear won't it?
Let me know, thanks.
Old May 24, 2006 | 03:45 AM
ARD T2's Avatar
Front NO. rear yes.
You know there's fitment guides bro. Stick within those ranges.
This is what I recommend in terms of limits.
Front:
8.0 +38
8.5" +40
9.0" +45
10.0" +50
Rear:
9.0" +38
9.5" +40
10.0" +45 for up to 275; +50 for a 285.
Now a lot of this depends on tire width, but this is for standard tire section widths appropriate for these widths and whatever diameter you chooose.
Rishie
Old May 24, 2006 | 11:09 AM
HardHitter's Avatar
Thanks Rishie,
I took your advice and am saving up for a true quality set of wheels. I don't know if I'm getting SF-Challenges as they are probably much too expensive, but I really love the Gram Light 57Pro's so that's most likely what I'm saving up for. Those in a RMC finish. Have you put those on any cars before? Also, I know you have a deal with the 57Pro's a while ago, is that deal still holding true or did that end?
Old May 24, 2006 | 06:15 PM
cabaynes's Avatar
Old and grumpy
FYI I am running
18x9 +43 with a 255/30
18x10 +43 with a 285/30
as per Rishie's reccomendations But they're at the absolute limits of the stock fenders for sure.
Can I ask why you want 19s?
Old May 24, 2006 | 11:58 PM
ARD T2's Avatar
I'm sure stoke means 255/35's not 30's. I could be wrong tho. And ya he's at the limits. The rears had to have been rolled or something for that to work as well.
Rishie
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
