Old 05-23-06, 10:28 AM   #1
gxl90rx7
breaking stuff
gxl90rx7's Avatar
Send a message via AIM to gxl90rx7 Send a message via Yahoo to gxl90rx7
2.0 mounted PDA setup pic thread
So iI should be getting the 2.0 in the mail this week, and im trying to find a way to mount the PDA in the dash some how, for on the fly monitoring, as well as easy access for tuning. Please post your setup for mounting your PDA, if you did something similar
gxl90rx7 is offline   Reply With Quote
Old 05-24-06, 10:23 PM   #2
Slo Motorsports
Drive it like ya stole it
Slo Motorsports's Avatar
Send a message via AIM to Slo Motorsports
What we did was run the cable into the glovebox. We wrap the Palm in foam and leave it logging while we race our auto-x events. Our thought for non-race situations was to use velcro and attach it to the dash just above the center vents.
1988 TII RX-7 Tenth Anniv. Ed.
RB Turbo back exh, HKS CAI, RB Fr/Rr Sway bars, RB Frt Strut Brace, Power Slot Rotors, Hawk HPS, Rtek 2.0 ECU w/Palm Pocketlogger, HKS Twin Power Ignition, RB Race Wires, HKS Iridium Plugs, HKS SSQ BOV, Tokico Illumina V w/RB springs, Cobra Imola S/GT Seats, Autopower 4 Point Roll Bar, Schroth 6 Point Harnesses, Mazdatrix Short Shifter, WedsSport TC005 16x8 rims, Kumho ECSTA 225/50WR16 V710's
1993.5 Premier Edition Supra TT Hardtop (rare, oh yeah)
Slo Motorsports is offline   Reply With Quote
Old 08-05-07, 12:19 PM   #3
gxl90rx7
breaking stuff
gxl90rx7's Avatar
I finally got around to finishing my setup, check it out:
I picked up this Tungsten T3 for about $150, it has a nice backlit color screen good for using at night.
I also picked up a TomTom Navigator 5 system, which works through bluetooth connection to the pda to enable realtime GPS navigation that ran me about $200 new
I also ordered the Tungsten t3 serial cable from pocketlogger, since it didnt come with one.
Next, i made a mount for the pda. i cut, sanded & painted a piece of thin aluminum and with a small bend on one side. Attached velcro to the back of it and the pda
i drilled two small holes into the center console, and screwed down the mount:
next came the difficult part.. I wanted a way to keep the pda charged using the car's power, but the Tungsten t3 has no separate power port.. It gets charged through its cradle, which connects through its own proprietary connector. So, i found the pinout for the connector, and it turns out pin 0 was GND and Pin 16 was 5V charge.. it also turns out the TomTom came with a 12V to 5V adapter So i gutted the adapter, wired the input straight to 12V (used the power source from the cig lighter), and split the output into 2: one for the TomTom receiver and one for the PDA. I took apart pocketloggers cable, and soldered a pair of wires to Pin 0 and 16, and made a connector to connect to the 5V adapter. Heres a pic of the modified pda connector:
So now, the pda charges whenever teh ignition is on, so you dont ever have to worry about charging your PDA
final result:
it works pretty good, no problems so far. but i havent had a chance to drive it yet and test the GPS due to the turbo being upgraded. so i may have to find a better spot for the receiver.. right now i just have it under the stereo. but it shouldnt be too difficult to route it up to the dash and mount it under the windshield somewhere
but it should work out pretty well, you can have it set to show rtek log data while driving or the GPS navigator constantly without batteries running out
1988 RX-7 TII 10AE BNR Stage 3, Haltech E6k
S5 TII OEM sideskirts replica group buy:
Old 09-15-07, 04:23 PM   #4
Slo Motorsports
Nice job. Have fun with it.
Old 09-29-07, 06:34 PM   #5
13b-series
I'm wanting to do this as well, I have one question about the pinout/wire color on the pda's serial end since I must have pinched the cable at one time. thanks
13b-series is offline   Reply With Quote
Old 10-07-07, 03:35 PM   #6
staticguitar313
R.I.P. Icemark
staticguitar313's Avatar
Send a message via AIM to staticguitar313
how did you pry apart the connecter to modify it? how do you know which pin is 0 and 16? amazing setup BTW
1993 VR Touring FD STREETPORT ENGINE BUILT BY GLEN WEAVER.
WTB: FD rear seats.
staticguitar313 is offline   Reply With Quote
Old 10-07-07, 05:02 PM   #7
gxl90rx7
breaking stuff
gxl90rx7's Avatar
thanks! i beleive the connector had two small screws, so it came apart easy
heres where i got the pinout: http://pinouts.ru/PDA/palm_m125_pinout.shtml
the only thing that sucks is that my GPS reciever has to be powered on manually every time you use it, I wish it would just power on whenever the ignition was turned on, but no..
Old 10-07-07, 07:24 PM   #8
YaNi
RIP Mark
YaNi's Avatar
Send a message via AIM to YaNi
Is the switch on the GPS receiver on/off or momentary? You could setup a relay switched with the ignition...
I'm not a rotary expert, but I did stay at a Holiday Inn Express last night...
Glad my hard earned money is going to someone else! - MaczPayne
YaNi is offline   Reply With Quote
Old 10-07-07, 08:50 PM   #9
gxl90rx7
breaking stuff
gxl90rx7's Avatar
no, its a momentary digital button on the receiver itself.. to turn the receiver on, you have to hold the button down for 3 seconds, so no easy way to rewire it..
Old 10-08-07, 01:42 AM   #10
staticguitar313
R.I.P. Icemark
sexy, thanks a bunch, i guess i'll be buying a T3 as well for my tii, and i just realized you have the same JVC deck that i do, only mine is still sitting in a box LOL.
WTB: FD rear seats.
Old 10-09-07, 12:42 AM   #11
13b-series
Thanks that pinout helped alot, now I think I need to figure why my T3 or ecu drops signal for under a second and comes back. Again thanks
Old 10-09-07, 11:49 AM   #12
gxl90rx7
breaking stuff
gxl90rx7's Avatar
ive seen that too, on both the T3 and my old m100. especially when changing values in the timing tables. i think its a fault with the pocketlogger software
