Old 05-22-06, 10:52 PM   #1
winter39
Got Rotors?
winter39's Avatar
Supporting Mods for Rtek 1.7
OK,
I have a read a ton about the Rtek 1.7 and necessary mods but i stumbled accross a search taht said a FP? is required???
I have the 720 secondaries, Apex BOV, 2.5" intake and Rtek1.7 almost installed now. Do you require an upgraded fuel pump too???
After this is all up and running I will be putting on a 3" RB exhaust to take advantage of the Rtek's capabilities.
Anything I might have missed please let me know.
Thanks
1988 AE TII
Rtek1.7, 720 secondaries, Apexi BOV, Custom Cone Intake, +++
winter39 is offline   Reply With Quote
Old 05-23-06, 01:16 AM   #2
turbo2ltr
From http://www.pocketlogger.com/index.ph...rtek7_techinfo
So with Rtek Stage 1.7, 720 secondaries, and a larger fuel pump, you should have a setup that can push the stock turbo to its safe limit (approximately 12 PSI).
Do you need a fuel pump? No, but then the above statement does not apply to you. You may/may not have enough fuel. It's up to you to make sure.
But a FP is one of the first/ most basic upgrades. It's highly recomended if you plan on modding your car.
turbo2ltr is offline   Reply With Quote
Old 05-23-06, 08:45 AM   #3
winter39
Got Rotors?
winter39's Avatar
Thanks,
I have a Walboro ready for install, just was putting it off for later if it was not critical. I will add this to my mods shortly. Thanks for the feedback.
