Vmount intercooler ina 20B FC
Old May 20, 2006 | 02:08 AM
onefastrx7's Avatar
Hi guys,
I would love to do a Vmount setup for the intercooler/radiator in my FC with the 20B. I think that would provide the best cooling period. Both the IC and the radiator will get cold air. How much room is there though?
I have a 600x300x100mm intercooler, and an AFCO 3" radiator. I was thinking about cutting the upper radiator support, relocating relays, horns, etc, and installing it like that. Is there enough room in a 20B setup though?
I also have a 13B RE that is going in the same car. Fully built, with full bridge port, Atkins 3mm seals, etc. I am planning on running the same parts on both engines - Haltech E11V2, GT42R, HKS 60mm GT2 wastegate, AFCO radiator, intercooler, Tial BOVs, OS Giken triple disk clutch, TII tranny, cosmo mounts, etc. I already have these parts. The only differences would be in a couple IC pipes, 2 extra coils, several wiring subharnesses, the exhaust manifolds,and the downpipe.
After that, I can swap in engines in a matter of 2-3 hours. So every other week I can drive the setup I want.
Thanks for your input...
Old May 22, 2006 | 07:09 AM
20B10AE's Avatar
Gone Darkside
Bastard! My idea! Heh.
Seriously though, I've thought about that same thing. I'm still trying to determine if it's worth doing or not. It would definitely be trick though! I think that your idea for a location is a good one. It's the same thing I had in mind as well.
Good luck with it! If I actually get to work on mine, I'll keep you updated.
Reese
Old May 25, 2006 | 11:38 PM
onefastrx7's Avatar
Reese
I took some measurements, and there is plenty of room, so that setup should work great.
I will post pictures soon...
Old May 25, 2006 | 11:58 PM
ABIEX's Avatar
I have 20b in my fd and i have made a v-mount solution for it...it seems to work good, have not started the engine yet but looks good i will put some pictures soon maybe other fd owners likes the look!
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
