Canadian Forum Canadian users, post event and club info here.
how to start it (please help)
Old May 18, 2006 | 11:34 PM
drummedoutboy's Avatar
So this car was given to me after 10 years of sitting around. (82 fb) The problem I'm having is keeping the car started for more then 20 seconds. I do believe that the engine floods but I can't figure out why. I really need some help if anybody is willing to come by. I have tons of tools and I’m will to pay. The car is in Simoce and I will be working on it Monday (22nd) and Tuesday (23rd) all day long. I don't think much is need to eliminate this problem.
Any suggestions are greatly appreciated since this is my first seven.
Old May 19, 2006 | 11:43 AM
Dom's Avatar
Dom
callin' tokyo
Drain the gas yet???
Old May 19, 2006 | 06:07 PM
Nova7's Avatar
Off hand I'd say you need to thoroughly clean the carb (I'm thinking it has a carb rather than EFI). If it's flooding it can be from the float in the carb bowl being too high or dirt in the shut off valve, etc. It could be a lot of things in the fuel system. I would clean everything from the tank forward if the car has sat for 10 years.
Old May 19, 2006 | 06:43 PM
I did get a new gas tank but how hard is it to clean the carb... is that something i can do myself. I have some experience working with cars but I never did anything carb related.
Old May 19, 2006 | 09:25 PM
dufourmike's Avatar
TRUST PWRD
you need a new carb, the seals have dried out, and look like old man hands. get a rebuild kit for 30-50 bucks, and any old hotrodder will easily fix it pretty cheap. or you can do it yourself
Old May 20, 2006 | 11:01 AM
Nova7's Avatar
Yea, rebuild the carb yourself. It's not hard, just take it apart slowly, lay the pieces out in order and put it all back in reverse order. Do you have a manual of any kind? It should show a breakdown picture of the carb and all it's pieces.
Old May 20, 2006 | 05:25 PM
dufourmike's Avatar
TRUST PWRD
im gonna be doing one soon, so ill let you know how it is.
Old May 20, 2006 | 06:32 PM
Ctrl's Avatar
My other car is a TVR
If it' sat for a long time, full choke and WOT worked for me.
Old May 20, 2006 | 09:09 PM
chedda_j's Avatar
YEah that basically worked for me too. btw tho, how do you set the float in these cars? I know how to change the airfuel mixture, and the idle. Does the AF mixture screw do basically this?
Old May 21, 2006 | 02:22 AM
Alak's Avatar
Maybe possible the seals are sticking on the rotors? Just a thought.
I personally would work my way from the carb down.
Old May 21, 2006 | 09:24 AM
dufourmike's Avatar
TRUST PWRD
Hmmm.... looks like there is enough compression to get it going, which is 9/10's of the battle. sounds like it is the carb, and that the floats are locked in a spot, or the seals are dry, and are leaking gas in.
Old May 24, 2006 | 07:41 PM
Thanks a lot...his should keep me buys for a while. I will rebuild the carb and then i will see what happens after that.
Old May 24, 2006 | 07:50 PM
dufourmike's Avatar
TRUST PWRD
I tore down the carb, looks like it wouldnt be hard to rebuild at all. Basicly the bigges tthing would be to clean the dirty stuff, which it doesnt look like there is much of
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
