99SPEC brakes
Old May 5, 2006 | 11:37 AM
dogzilla's Avatar
Exclamation 99SPEC brakes
What's is the difference between the 99+ and pre 99 brakes system, both front and rear?
thanks in advance.
Old May 5, 2006 | 12:23 PM
rynberg's Avatar
Calipers are same except fronts are wider, rears have longer brackets. Rotors are 12.4", 1.25" wide up front, 0.79" in back.
Old May 5, 2006 | 01:05 PM
dogzilla's Avatar
so is it really worth the money to upgrade the stock front calipers to 99+ calipers?
Old May 5, 2006 | 01:47 PM
rynberg's Avatar
You are gaining rotors that are 0.9" bigger in diameter and .25" wider. If you aren't road racing the car and exceeding the stock braking capability, then ANY brake "upgrade" isn't worth the money.
Tem120
Sep 7, 2015 09:53 AM
Frisky Arab
Sep 4, 2015 06:17 PM
