Rear Hatch Strut
Old Feb 13, 2002 | 08:47 AM
Directfreak's Avatar
I am a Jeeper Now.
Question Rear Hatch Strut
Where is a good place to order a new glass hatch strut?
I know Victoria British sells them, but several years ago,
when I had my previous Seven, I found an aftermarket one that
had like twice the lifting power to hold the hatch up.
I only needed one (left side) and I decided to leave the one with
the rear wiper assembly alone.
It worked great. I just want the same thing for my present 7
and don't remember where I got it.
Any Ideas?
Old Feb 13, 2002 | 09:01 AM
branca's Avatar
strutin.............
got my replacements at Carquest, (don't know if you have them in your area however). These struts are strong enough to keep the hatch wide open and drive the car, if I ever had to do it. I was also able to retain my rear window defrost hook up using a new strut. good luck
Old Feb 13, 2002 | 09:09 AM
DONNA's Avatar
took mine off a wrecked 91 eclipse just had to drill out the old pivit and reuse the original,,,about 2.00,,,,,,,bone yard
Old Feb 13, 2002 | 09:17 AM
yayarx7's Avatar
Are you Nucking Futs?
I found a couple a few years back and put one on the car and that one did the job(no rear wiper). Saved the other one till I picked up the 80.
don't remember the brand, think I got 'em at pep boys, coulda been autozone though. not much help huh
Old Feb 13, 2002 | 10:47 AM
rxtasy's Avatar
sorry Directfreak, i can't really help, other than to say they don't list them in the auto stores around here anymore, i just measured mine and bought one that was the same size, works ok.
DONNA, u're freaking me out, everytime i pass by one of your posts i see myself in your avatar!! i keep forgeting that i don't use that one anymore so when i see the post i think 'when the hell did i answer this one?"
Old Feb 13, 2002 | 11:19 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
You can get threm from Advance auto parts, or auto zone for like 9 each. Why go through the trouble getting a used one?
Old Feb 13, 2002 | 12:37 PM
brownmound's Avatar
Anytime baby!
I think advance is where I got mine....the brand is strong man, or tuff man, or something like that I believe. Powerful as all hell, and you can use them with the rear wiper thingy. replace both at the same time otherwise you risk stressing the glass and hinges with unbalanced forces.
Right on
Old Feb 13, 2002 | 12:39 PM
moremazda's Avatar
Gone Race'n
got mine at Autozone 4 years ago. Finally removed one of them, due to the fact I had to climb on top glass and jump on it to get it down. I think they are $4/each.
Ryan
Old Feb 13, 2002 | 12:44 PM
Hey brownmound - how did you accomodate for the wiper on yours? Did you transfer the electrics to the new strut, or bypass in some way? I have wipers and alum louvers and need to have more oomph.
Old Feb 13, 2002 | 12:57 PM
brownmound's Avatar
Anytime baby!
If you get the tuff man/ strong arm/ whatever they are called lifts then the little round electircal doohicky will fit over the new strut....you have to cut the shrinkwrap which holds the wire to the strut, though...just replace it with heat shrink tubing or just a few tie wraps like i did.
good luck
Right on
Old Feb 13, 2002 | 02:16 PM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
I got my Strong Arm (#4709) lift from Carquest for $30 canadian. ABout $20 in the US if I'm not mistaken.... But you can by strong arm products from many auto parts stores and that part number I listed is Strong arms...
Old Feb 13, 2002 | 04:22 PM
I am a Jeeper Now.
Talking
THANKS FOR THE INFO!!
I will check out Brown Mounds Brand first, and if not, I will just measure
and get another one.
