Microtech Microtech cranking ms
Old Apr 27, 2006 | 09:44 PM
mazdarick's Avatar
LS1 Here I come.
I seem to be having a hard time starting my car hot or cold. Originally the screen was readint a 12.14ms while I was cranking, so I turned down the AFste, and the crank map a bit so I wasn't maxing them out, but I was wondering on what kind of a target I should be shooting for. It's really embarrassing when I stop at the pump to fuel up and get all these stares, when she won't start back up for a while. I would really appreciate any help I could get with this one. I think I'm somewhere around 9 ms now, but don't know if it's enough fuel, or too much. Thanks in advance.
Old Apr 27, 2006 | 09:46 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
my cranking ms is anywhere between 14-16ms for my wolf3d
where in maine? im in southern nh just south of wolfboro
Old Apr 28, 2006 | 06:58 AM
mazdarick's Avatar
LS1 Here I come.
Wow. I kept flooding my car with 12.14 ms. I think that's max on the Microtech. I know the injector stage at 99 affects the load and idle maps, but don't know if it affects the crank map at all. I won't think so as it's expressed as a percentage. Can anyone else post what their crank maps are set to???? By the way I'm located in Central Maine, Waterville/Clinton area. Check out our website at http://www.evo-imports.com. You should sign in and keep in touch, we could get together sometime. My club is planning a trip to NH this summer with all our cars. We've got 2 RX's that'll be there.
Old May 9, 2006 | 02:41 PM
Dom_C's Avatar
don't forget about my 7. . come on now Rick. .haha Unless Brett will be in his corrado that is.
Old May 9, 2006 | 07:29 PM
Spooledup300z's Avatar
12.14ms for cranking is high especially when the engine is warm, Check your coolant temp settings and make sure everything correspondes. The process of setting up your Crank setting and your Temp settings are time consuming cause you have to let the car cool then warm then cool them warm.... etc
Set you crank and temp settings to the right setting and you should be good.
Lee
Old May 9, 2006 | 08:08 PM
mazdarick's Avatar
LS1 Here I come.
I've got my crank maps set to -10 % now for most of my temp ranges. It now seems to be starting better, but I'm not sure why my crank ms is still around 10ms. I would think that -10 % would make it much lower, as in remove fuel while cranking, not add it. Once the car fires, it idles around 3 - 3.5ms. Isn't this abnormal. I also have the large 1600 secondaries and my staging is set at 99%. I don't know. I'll keep playing with it, it's just getting real frustrating.
Old May 10, 2006 | 02:35 AM
Iwan's Avatar
my crank times are stock, so should be in range of 12ms as well.
I run 550prim and 1000 sec injectors with %stage set to 91. I have 1.05 ms set for idle in the fuel map.
What AFR do you read at ide? What engine- modifications do you have? Is your engine heavy- ported, like a big bridge port or so?
REgards
Iwan
Old May 10, 2006 | 07:42 AM
mazdarick's Avatar
LS1 Here I come.
My car idles with an AFR of around 12.6-13.0. I have a decent street port, idles around 1000 rpm. Other than other bolt ons, the only engine mods are the street port (intake and exhaust), and the higher flow oil pump.
Aramir
Oct 18, 2015 02:39 AM
Robrods64
Oct 2, 2015 07:56 PM
93FD510
Oct 1, 2015 02:00 PM
Rotafuzz
Sep 30, 2015 09:55 AM
