LT1 in an FC
Old Apr 24, 2006 | 04:48 PM
rx7b13's Avatar
its been done alot if you look in the kills section i have a buddy and his name is hocky he has an ls1 swap and he has a video of killing bikes
Old Apr 24, 2006 | 04:50 PM
cdaleracer669's Avatar
yes,thats me \/
plenty of people swap in lt1 and ls1's.do a search in the engine conversion forum
Old Apr 24, 2006 | 05:50 PM
rajahFD's Avatar
teehee
liars!
Old Apr 24, 2006 | 06:11 PM
zumzum's Avatar
88 Vert in Elvis Land
I enjoy the LT-1 in my FC vert...
Old Apr 24, 2006 | 06:38 PM
digitalsolo's Avatar
RX-347
It's pretty tough. An LT1/T56 swap would take at LEAST 2 days. Maybe as many as 3!!!
Old Apr 25, 2006 | 06:46 PM
LT-x7's Avatar
I also run a LT1
Old Apr 26, 2006 | 12:06 PM
owen is fat's Avatar
rofl... but true!
its not a difficult swap, especially if you are just doing a motor swap and not an entire car buildup (susp.brakes/interior/etc)
I built my LS1 T56 FC but the LT1 swap is very similar. bolting up the transmission to the chassis is super simple. you should use a TII rear end (diff and halfshafts) and that will hold up just fine. you can have a steel or aluminum driveshaft made by any reputable driveshaft shop for pretty cheap ($100 steel, $250 aluminum) and that bolts right up without mods to the chassis. um, there is no "horrific nightmare of wiring" like you mention... there are only a dozen wires to connect and only half of those go to the rx7 chassis wiring.
the only electronics that do not work on my swap is the stock FC speedo. I did not use the stock oil pressure gauge or water temp gage in the FC cluster because they are inaccurate enough for me to not bother, although I did buy an aftermarket water temp gage to keep an eye on water temps, that is the one thing I wanted to keep an eye on. my fuel gage works and the tach works and the voltmeter works. to get the speedo to work you can buy an electronic to mechanical/cable converter box or buy an electronic speedo and install that in the cluster. I will be buying a $120 electronic speedo to get mine to have a complete cluster.
this can be done for reasonably cheap, like $2500 total for the swap to be drivable.
there is as much work involved in converting to a Tii from n/a.
Old Mar 1, 2007 | 01:53 PM
oakback's Avatar
meh
edit: sorry, didn't mean to bump an old thread!
eriksseven
Racing Kills Lounge
Mar 10, 2007 02:23 PM
rx-7Lt1
V-8 Powered RX-7's
14
Aug 1, 2006 09:15 PM
90FC
V-8 Powered RX-7's
May 26, 2006 06:18 PM
manatecu
V-8 Powered RX-7's
Feb 22, 2006 09:51 AM
twint78
V-8 Powered RX-7's
Dec 16, 2002 06:30 PM
