Megasquirt last ditch effort.
Old Apr 19, 2006 | 10:43 AM
SirCygnus's Avatar
whats going on?
last ditch effort.
well... i havent given up yet. if there is someone i can send my ms out to to check my wireing, i would appreciate it. but onto the real topic.
im thinking about buying the daughtor card. i figured it i cant get the det5oothed wheel to be recognized, then something on my ms board is fried. so im wondering this, if i buy the daughtor card with two vr cuircits, is there a way to bypass the stock ms circuit on the ms v 3 board?
Old Apr 19, 2006 | 12:41 PM
muythaibxr's Avatar
MegaSquirt Mod
there is a way to bypass that circuit as long as you built both the VR sensor circuit and the old opto-isolated circuit.
Old Apr 19, 2006 | 12:48 PM
muythaibxr's Avatar
MegaSquirt Mod
wiring up the error* board is more complicated than building the original circuit in the MS, and if the original circuit in the MS works on the stim, then most likely the problem is not with the MS, but with your wiring.
Old Apr 19, 2006 | 01:01 PM
SirCygnus's Avatar
whats going on?
well... are you asking if the cas worked on the stim? cus it didnt. no matter what or how i try, even on the bench, ms cannot read a signal from the cas.
Old Apr 19, 2006 | 01:40 PM
muythaibxr's Avatar
MegaSquirt Mod
no, I mean you had the original stimulator circuit working before you modded it to try to get it working with the CAS.
NotMrButts
Feb 10, 2018 06:36 PM
jeremyferguson4444
Sep 19, 2015 01:27 PM
kryan9
Sep 15, 2015 10:11 PM
Mags
Jan 23, 2002 01:04 PM
