Haltech Need help mounting the TPS on a 2nd Gen.
Old Feb 11, 2002 | 08:48 PM
1FastT2's Avatar
I need the mount the TPS on my 2nd Gen throttle body. I am going to still use my OMP, how did everyone do this, is there a trick or something that I dont know about? Please share!
Old Feb 11, 2002 | 10:13 PM
tims's Avatar
a thin piece of aluminum bent in a flat s type shape mounted to throttle body facing front of car. after removing all the junk from the throttle body there are three small threaded holes that can be used. can be built from a 1" or so piece of aluminum. drill a few hole and file the throttle shaft to fit the tps. hitman has a pic of one installed
Old Feb 12, 2002 | 07:16 PM
1FastT2's Avatar
What is there that I can remove? I took it all apart and it seems to me that I would need all that stuff.
Old Feb 13, 2002 | 09:40 PM
tims's Avatar
you really only need the last set of butterflies and a place for the tps and throttle cable. all the other junk is for the stock emissions and idle control. with the Haltech all of this stuff is just along for the ride. I plug all the extra holes with A/B epoxy. you only need one port for the MAP sensor. if you want to keep the stuff on the throttle body find somewhere that the tps can attach to the throttle and make a simple bracket. it doesn't need to be of 1/4" plate just needs to be stable and reliable.
Old Feb 14, 2002 | 05:50 AM
1FastT2's Avatar
Ok thanks, I removed the first set of butterflies and did plug the the holes and all the other junk thats that on there. I'll have to take a closer look what else I can remove on the main butterfly shaft.
Old Feb 20, 2002 | 06:16 PM
Moderator, please erase this
Old Feb 20, 2002 | 09:41 PM
NZConvertible's Avatar
I'm a boost creep...
This might help:
http://www.teamfc3s.org/webboard/Forum1/HTML/000702.php
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
incubuseva
14
Sep 3, 2015 12:37 PM
