Wheel Hop.
Old Feb 11, 2002 | 02:22 PM
Wheel Hop.
can anyone tell me what exactly Wheel hop is?
I've heard all sorts of things about it but i dont no what causes it and how to get rid.
Old Feb 11, 2002 | 02:24 PM
ttpowerd's Avatar
HARRRRRRRRR
basically when you launch and the back wheels don't stay on the ground
that is just teh basics...someone else will have to explain it better than I can
Old Feb 11, 2002 | 02:46 PM
TailHappy's Avatar
Addicted to Track
You'll know it when you get wheel hop! The whole car will shake violently and you'll even be able to see the shifter shaking back and forth. First time I had it happen I was convinced I must've broken something. Like ttpowerd said, the wheels are hopping, so they keep grabbing and then hopping again. Tends to happen at the limit of traction. If you totally break the wheels loose, it usually won't hop.
I've heard that it's a result of the toe-in not being held stable under hard power. As the toe-in gets bad enough, it hops back into place and then does it again. There's extra links you can buy and bushings and stuff meant for drag racing, but I've heard it's so much trouble that you're better off just not giving it so much gas on the launch and not worrying about it.
Old Feb 11, 2002 | 02:50 PM
ttpowerd's Avatar
HARRRRRRRRR
I got the m2 trailing arms that are supposed to stop or significantly reduce wheel hop. Look for the thread I started "Installed m2 trailing arms" it was only a couple of days ago that I wrote that so it should be easy to find. I have not tried to lay into it yet bc my clutch is slipping so i don't know how well it helped but we will see if a month or so
Old Feb 11, 2002 | 05:14 PM
YES I had wheel hop!
Fu*in shi* myself! Thought I broke somert! Well my teeth
Must see dentist
Old Feb 12, 2002 | 12:22 PM
Sounds like you need M2 Trailing Arms.
LoL
Is it right its when the wheels jump off the floor and spins then grips, does this sound right?
Why does'nt the Lsd stop the car from doing this? is it becouse the back end is light and maybe the Suspention is to Soft?
Would it only do this from Stop starts or would it do it half way around a corner?
Old Feb 12, 2002 | 02:55 PM
TailHappy's Avatar
Addicted to Track
My sentiments exactly mr rx, when mine did this!
Yeah, the wheels are physically hopping of the ground, and I've even heard of the hop being visible in extreme cases. The LSD doesn't help because BOTH tires get to hopping, and the LSD is just making sure that they both spin. I have heard that it isn't so much because due to the tail being light (which would just result in spinning, not hopping), but more so because the stock suspension can't keep both wheels pointing perfectly straight (thus the aftermarket trailing arms).
I autocross and have had fairly bad chatter when searching for traction leaving a turn, but generally it's only on hard launches. I assume it's just because launching puts the most stress on everything. I think the slop in my drivetrain isn't helping anything...
HTH
Old Feb 12, 2002 | 04:10 PM
ttpowerd's Avatar
HARRRRRRRRR
you could always invest in jimlab's bushing kit...pm him for more info
Old Feb 12, 2002 | 08:14 PM
Import Convert's Avatar
Wheelhop is no fun. My truck wheels have done that to me a couple times. Once it made CD player skip.
FB_Frank85
Sep 6, 2015 11:29 AM
