Microtech What TPS to use - MIcrotech LT8S - FC3S
Old Apr 7, 2006 | 03:44 PM
Ni5mo180SX's Avatar
White Comet
So the car is an FC, engine is 13BT. Is there a broader range and more accurate TPS Sensor I can use with the Microtech to better calibrate things with? The stock single piston (S4) TPS has a range of something like "idle", "partial throttle" and "WOT" after 60% throttle I believe. Is there something with better range then this such as the GM or Ford type sensors? Thanks.
Old Apr 7, 2006 | 03:53 PM
luiml73's Avatar
Rotary Powered Boobies
I used this
Ebay ford Tps $24
https://i16.ebayimg.com/04/i/05/cc/72/03_1_b.JPG
Old Apr 7, 2006 | 07:59 PM
Turbo Timmy's Avatar
Professional Lurker
TPS is only used for idle. Stock one works fine.
Old Apr 7, 2006 | 11:29 PM
z-beater's Avatar
REW'd FB
I don't plan on using one
Old Apr 7, 2006 | 11:34 PM
Ni5mo180SX's Avatar
White Comet
So how does the ECU know the amount of throttle load? I know its MAP based but can't it be used in conjuntion with some kind of throttle positioning sensor to increase accuracy?
Old Apr 14, 2006 | 02:16 PM
Ni5mo180SX's Avatar
White Comet
anyone?
Old Apr 30, 2006 | 03:58 AM
bobybeach's Avatar
stock tps is gd for stock ports, but once you have large overlap you are better of with a more acurate tps since load map is more accurate with the tps signal than the map signal.
mind you in saying that, mine is only reading a range of aprox 25% throtle. so maybe a gd one that reads 60% of the throtle will work a treat.
Einheri
Oct 7, 2015 12:23 PM
