Italian vs. Spanish 48 IDA's
Old Mar 24, 2006 | 01:55 PM
Jaime Enriquez's Avatar
OLDROTA
Just wondering...
I know the older I-Ti vesion has brass squirters that look a little longer. Aside from that, any real difference power or drivability wise?
Old Mar 26, 2006 | 08:22 PM
PDF's Avatar
PDF
I haven't noticed any tuning/power differences between the new and old.
Old Mar 26, 2006 | 09:10 PM
680RWHP12A's Avatar
no differences as far as driveability, just some minor parts are different..
Old Mar 28, 2006 | 10:42 AM
rotaryengineering's Avatar
Difference between older/newer 48 IDA Bodies
The difference is the casting. The older units had way more material if you wanted to bore to 51.5 or 52mm. I actually like the older screw in type pump jets instead of the new press in type personally.
Albert
Old Mar 28, 2006 | 11:23 AM
680RWHP12A's Avatar
Albert
obviously the castings are different, they are made in 2 different factorys!!lol
and as far as the older webers having thicker castings, i call b.s. ! i have a newer ida thats been opened up to 51.8 mm , thats pretty close to 52 mm and its still got some material left.... i will agree with you on the acc pump jets, the o-ring type leaks easily so you've got to make sure the o-ring is perfect.. hi albert
dona1326cosprings7
Oct 29, 2015 06:47 AM
GKW
Sep 28, 2015 04:34 PM
