oil pressure questions
Old Feb 8, 2002 | 01:56 PM
rally on's Avatar
hi all,
i just bought a 95 and had a question about the oil pressure gauge. the car is currently running 20w-50 oil (from the previous owner). at startup, the needle reads about 60psi. but once warmed up and at idle, the gauge needle hovers just barely over the 0 mark (with no warning light). while cruising, it's rises and holds steady at the 40psi mark. the dipstick indicates 3/4 full. could the high viscosity oil and low temperature (~40F) be causing such a low oil pressure reading at idle? what range are you all getting?
thanks in advance!
Old Feb 8, 2002 | 02:20 PM
Mahjik's Avatar
Mr. Links
Lightbulb
Check the oil pressure sending unit harness. It's below the oil filter, sometimes it gets dirty from oil/dirt and sends some strange readings.
Old Feb 8, 2002 | 03:44 PM
mjw's Avatar
mjw
Re: oil pressure questions
Originally posted by rally on
hi all,
thanks in advance!
Take his advice and check the harness. A higher viscosity oil in tandem with low temps should yield higher oil pressure.. in 40F weather I would never run 20w50 oil.. too thick.. just my opinion.
Matt
93 touring
Old Feb 8, 2002 | 05:54 PM
Sidestick's Avatar
And remember that oil light is a low oil QUANTITY light.
The stock oil pressure sender goes bad over time & a low pressure reading at idle isn't necessarily low press. As Mahjik said, unplug the connector from the sending unit below the oil filter & clean up the gunk on the sender & connector.
andyvideopro
Aug 20, 2015 10:55 AM
20B Forum
Aug 18, 2015 02:46 PM
