Megasquirt mixed injectors
Old Mar 18, 2006 | 11:23 PM
West-se's Avatar
bcrotary.com
mixed injectors
I am looking at adding some larger secondaries, however they are high impedance, I am running low impedance right now (s4) I know i've read before that you can bypass the resistor pack for the secondaries and run mixed impedance. Will MS be able to control mixed impedance injectors ? does the PWM % or time differ for each type?
Old Mar 19, 2006 | 03:15 AM
muythaibxr's Avatar
MegaSquirt Mod
If you use the resistor pack for the primaries, and bypass it for the secondaries, you can just set everything up as high-impedance. You shouldn't have any problem doing that.
20B Forum
21
Mar 22, 2022 01:00 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
