What springs for RA apex seals
Old Mar 16, 2006 | 03:00 AM
BuckyFD3's Avatar
GT4088R
I have just ordered a rebuild kit which is using 2mm RA seals, from reading about the springs flattening out and others being used instead.
What options are there???
Old Mar 16, 2006 | 04:19 AM
ProjectD's Avatar
I'm on a Boat!
From what i've read stock springs are gonna be your best bet. That's what i have in the motor i'm currently building.
Old Mar 16, 2006 | 01:04 PM
diabolical1's Avatar
use Mazda seal springs
Old Mar 16, 2006 | 04:04 PM
t-von's Avatar
Rotor Head Extreme
The stock springs are heat treated. The RA springs are not.
Old Mar 17, 2006 | 02:19 AM
BuckyFD3's Avatar
GT4088R
What are the atkins ones like??
Old Mar 17, 2006 | 03:43 PM
drago86's Avatar
i'm doing fine with the RA springs.
Old Mar 18, 2006 | 11:35 AM
BuckyFD3's Avatar
GT4088R
Change of plan, I'm going with the 3mm seals now. Getting them to swap them over. I havn't pulled the engine apart yet so dont know the condition of the rotors and 3mm will give me a little extra strength.
Since these are 1 piece seals, different springs are to be used. What are people using?? I know they are mazda OEM ones but I read somewhere they are from a different model.
Old Mar 18, 2006 | 01:13 PM
any pre-1986 13B engine ... just order for the 85 Rx-7 GSL-SE
Old Mar 18, 2006 | 01:17 PM
BuckyFD3's Avatar
GT4088R
Cheers I'll get them ordered monday.
Old Mar 20, 2006 | 01:05 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
anyone know how to properly heat treat the springs? i always use stock springs, and i've probably got 10 or 11 untouched sets of RA springs. might as well put them to use if i can.
Old Mar 27, 2006 | 04:49 AM
BuckyFD3's Avatar
GT4088R
Just got my 3mm seals threw today, I thought they were 1 piece seals but they are 2.
They use single springs so are "any pre-1986 13B engine ... just order for the 85 Rx-7 GSL-SE" springs still used???
Old Mar 28, 2006 | 02:39 AM
t-von's Avatar
Rotor Head Extreme
Someone needs to engineer a small spring for the 3mm seals like the 2mm seals have. The small spring would help keep the apex seal from sagging in the middle.
Old Mar 28, 2006 | 09:22 AM
BuckyFD3's Avatar
GT4088R
I might buy 3mm dual springs and machine the seals to fit them.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
