Microtech How do i hook up my speedometer with microtech?
Old Mar 8, 2006 | 05:55 PM
fastcarfreak's Avatar
3rd motors a charm I hope
hey guys, im getting sick of not having a speedometer. I cant seem to figure out how to hook it up... I have the wires from the transmission leading into the car, and i need to know which wire comes from the trans that is for the speedometer, and which wire do i hook it up to??? thanks in advance...
Adam
Old Mar 10, 2006 | 09:58 AM
cmon guys, has nobody hooked their speedometer back up after their microtech install?
Or am i way off on my thinking?
Old Mar 10, 2006 | 05:32 PM
Crusader_9x's Avatar
Your way off, the speedo is mechanical. The cable runs from the back of the tranny to the back of the speedo. It screws in on both sides.
Old Mar 11, 2006 | 10:09 AM
you sure? that sounds kind of wierd for a car from the 90s... How come it stopped working after the microtech was installed? And how would i get it functional again?
Old Mar 12, 2006 | 05:18 PM
If you have a third gen then Im not to sure. I always default to a second gen. Guess Im biased lol.
Old Mar 13, 2006 | 08:35 PM
Broken09's Avatar
I am becoming...
Is it just the speedo that isn't working or are other parts out as well?
Old Mar 21, 2006 | 07:45 AM
well, pretty much none of my guages in the dash are working. But none of them are hooked up either.
Old Mar 21, 2006 | 10:52 AM
Broken09's Avatar
I am becoming...
check your connectors by the passenger side and make sure all your grounds are good. I had the same problem with mine. It ended up just being a bad ground there by the passenger side area
Old Mar 22, 2006 | 06:20 AM
REVHED's Avatar
Hunting Skylines
I think you may have just found your problem.
Old Mar 22, 2006 | 04:38 PM
i understand this, that is why im trying to figure out how to get them hooked up...
dona1326cosprings7
Oct 29, 2015 06:47 AM
MidnightOwl
Sep 25, 2015 10:24 PM
