Need Help Regrounding Engine Components
Old Feb 27, 2006 | 02:21 PM
GunmetalRX's Avatar
Exclamation Need Help Regrounding Engine Components
ive got the famous 'hesitation problem of 3800rpm', and i need to know where the ground wires are in my engine bay so i can reground everything.
suggestions for new grounding points and where to start the wires from is needed.
Old Feb 27, 2006 | 03:05 PM
Sgtblue's Avatar
Urban Combat Vet
Negative battery terminal to chassis
Negative battery terminal to engine
Engine to Chassis
IIRC, I used some 8 gauge wire I had laying around.
Old Feb 27, 2006 | 04:06 PM
GunmetalRX's Avatar
yeah i got 10 feet of JL 8 guage wire...now, are the various grounds you mentioned the same on an 87 N/A which i have? i noticed it said you had 93...and do i have to remove the old grounds to put new ones on? my friend said all i had to do is put on new ones, and the electrons would follow the better path.
Old Feb 27, 2006 | 06:51 PM
Sgtblue's Avatar
Urban Combat Vet
I really don't think it makes a big difference exactly where they go, just as long as it makes good contact.....not through paint or a rusty bolt. And no, you don't have to remove the old grounds. Just add.
12abridgeport
Aug 17, 2015 06:28 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
