.. specs for the width of a gslse rear axel
Old Feb 22, 2006 | 02:27 PM
squagles's Avatar
anyone have specs for the width of a gslse rear axel?
like wheel to wheel or whatever you want to call it.
and anyone also know the width of the stock rx3 rear tire to tire as well?
Old Feb 22, 2006 | 11:43 PM
islandsnow's Avatar
stock wheel is 5.5 offset is (correct me if I'm wrong) + 25 I'll have to measure the rear end tomorrow from end to end. But the axel it self is 28 3/8" if that helps any.
Old Feb 22, 2006 | 11:49 PM
islandsnow's Avatar
Are you going with the SE rear for your RX3?
Old Feb 23, 2006 | 12:13 AM
squagles's Avatar
ya i am,
i just bought a almost brand new mazda comp lsd with new 4.44 gears in it and its for a 85 gslse so i have to go with that now.....i really want to use the lsd
Old Feb 23, 2006 | 09:52 AM
islandsnow's Avatar
55 1/8" from disk to disk.
Old Feb 23, 2006 | 02:32 PM
squagles's Avatar
thanks where did you get that info?
or did you do it the ols fashioned way ie tape measue?
now i just need to get the rx3 measurement and im set.
thanks again/
Old Feb 23, 2006 | 04:26 PM
Re-Speed.com's Avatar
I took some measurements a while back for my REPU project. I came up with:
GSL-SE: 58 1/2" wide - Wheel flange to Wheel flange
This measurement is from each wheel mounting surface. This way your only variable is your wheel backspace and width.
-billy
Old Feb 23, 2006 | 05:26 PM
islandsnow's Avatar
thanks again/
I measured it from disk to disk using a tape maeasure...... Now take your rx3 rear end measure it from disk to disk and give me the measurement.
Old Feb 23, 2006 | 07:23 PM
autopaul's Avatar
lightened fb
i have a housing for an axle housing for an 84 gs model car.. i bought it before i got a complete se rearend cause i was gonna build it all up since it fits all the se parts depending on whether you want to use the se brakes...
.. its partially sandblasted
anyway.. my point is that im not using it anymore.. i notice your in vancouver its up for sale... if your interested give me an offer..
Old Feb 24, 2006 | 12:19 AM
squagles's Avatar
does it have breaks and stuff on it?
and what stud pattern would that be?
Old Feb 27, 2006 | 03:51 PM
autopaul's Avatar
lightened fb
just the housing... you could put whatever axles and brakes you want on it
Paul
auggie463
21
Sep 2, 2015 01:46 PM
