Microtech anyone runing a s413bt, maps?
Old Feb 20, 2006 | 01:49 PM
abuse13bt's Avatar
Newbie
Question anyone runing a s413bt, maps?
hey just needing some maps for a series 4 13bturb, microtech i duno, any tips or ideas, thanks
Old Feb 20, 2006 | 07:06 PM
Raton's Avatar
Hey..., I was looking for the setup thats what i have on my car now..., but I'm having problems with the Idle...., my car is a 13b TII series 4...., I hope this will help you
Screen 01
IDLE
00"hg 4.00
05"hg 3.48
10"hg 2.48
15"hg 2.38
20"hg 1.93
25"hg 1.48
30"hg 1.33
2 psi 4.95
4 psi 4.95
6 psi 4.95
8 psi 4.95
10 psi 4.95
14 psi 4.95
16 psi 4.95
18 psi 4.95
20 psi 4.95
Screen 02
AUX
20 psi 0
18 psi 0
16 psi 0
14 psi 0
10 psi 0
8 psi 0
6 psi 0
4 psi 0
2 psi 0
Screen 03
Load
20 psi 10.00
18 psi 9.48
16 psi 9.00
14 psi 8.71
10 psi 8.48
8 psi 7.86
6 psi 7.14
4 psi 6.10
2 psi 5.62
00"hg 4.81
05"hg 3.90
10"hg 2.90
15"hg 2.24
20"hg 1.95
25"hg 1.86
30"hg 1.76
Screen 17
RPMwot
500 00%
1000 00%
1500 00%
2000 00%
2500 00%
3000 00%
3500 00%
4000 00%
4500 00%
5000 00%
5500 00%
6000 00%
6500 00%
7000 00%
8000 00%
9000 00%
Screen 18
RPMcrs
500 00%
1000 00%
1500 00%
2000 00%
2500 00%
3000 00%
3500 00%
4000 00%
4500 00%
5000 00%
5500 00%
6000 00%
6500 00%
7000 00%
7500 00%
8000 00%
Screen 19
Pump
Pump2Start 2000
Pump1 Amt 10
Pump1pulse 02
Pump1Trig 14
Pump1Stop 00
Pump1ADV +5
Pump2Time 10
Pump2Amt 30
Pump2Trig 16
Pump2Stop 00"Hg
Pump2ADV +05
Pump Dwell 3.00
Pump Timers NO
Pump1 Sync NO
Pump Spare +00
Pump Cold +00
Screen 20
Water
124 C 00%
99 C 00%
82 C 00%
68 C 8%
60 C 12%
46 C 15%
38 C 20%
31 C 30%
24 C 35%
18 C 45%
11 C 50%
5 C 50%
-1 C 55%
-9 C 60%
-17 C 70%
-25 C 00%
Screen 21
Air_t
124 C 0
99 C 0
82 C 0
68 C 0
60 C 0
46 C 0
38 C 0
31 C 0
24 C 0
18 C 3
11 C 3
5 C 4
-1 C 5
-9 C 6
-17 C 8
-25 C 00%
Screen 22
Crank
124 C 0
99 C 0
82 C 0
68 C 5
60 C 15
46 C 20
38 C 26
31 C 31
24 C 41
18 C 50
11 C 57
5 C 62
-1 C 67
-9 C 72
-17 C 72
-25 C 72
Screen 23
t rpm
500 0
1000 10
1500 15
2000 20
2500 25
3000 25
3500 25
4000 25
4500 25
5000 25
5500 25
6000 25
6500 25
7000 25
7500 25
8000 25
Screen 24
t map
20 psi 06
18 psi 06
16 psi 05
14 psi 04
10 psi 03
8 psi 02
6 psi 00
4 psi 00
2 psi 00
00"hg 00
05"hg 00
10"hg 02
15"hg 03
20"hg 04
25"hg 05
30"hg 00
Screen 25
t air
124 C +00
99 C +00
82 C +00
68 C +00
60 C +00
46 C +00
38 C +00
31 C +00
24 C +00
18 C +00
11 C +00
5 C +00
-1 C +00
-9 C +00
-17 C +00
-25 C +00
Screen 26
t gap
500 15
1000 15
1500 15
2000 14
2500 12
3000 10
3500 10
4000 10
4500 10
5000 10
5500 10
6000 10
6500 10
7000 10
8000 10
9000 10
Screen 27
t Inj
500 120
1000 150
1500 150
2000 150
2500 150
3000 150
3500 180
4000 180
4500 210
5000 210
5500 210
6000 240
6500 240
7000 270
8000 270
9000 270
Screen 28
t wat
124 C +00
99 C +00
82 C +00
68 C +00
60 C +00
46 C +00
38 C +00
31 C +00
24 C +00
18 C +00
11 C +00
5 C +00
-1 C +00
-9 C +00
-17 C +00
-25 C +00
Screen 29
Auxiliary Output
Aux out RPM OFF
Aux out MAP OFF
Aux out INV OFF
Aux Fan ON OFF
Aux Pwm1LO .76
Aux Pwm1HI 7.62
Screen 30
Options
Opt MIXtrm 00%
Opt TPScal +34%
Opt TIMtrm +00%
Opt Static +00%
Opt TIMmax +27
Opt RPMwot 04"
Opt RPMcrs 17"
Opt AF_ste 10
Opt REVlim 08%
Opt REVcut OFF
Opt BstCUT OFF
Opt IDLmap OFF
Opt REVstg 3000
Opt MAPstg 05"Hg
Opt %stg +50%
Opt Decel OFF
Opt Dwell 3.00
Screen 31
Prog #1 13Bt 1.0
MAPS NORMAL
Config +04 Cyl/R
Firing SEQUENTIAL
LOAD = MAP Sensor
DWELL = Time base
Input Trig +VE
Spark Trig SER 4
Timing check OFF
Rpm_ON 2500 log
Map_ON 02 psi
Sample +00 Log
Spare +00 Log
SHIFT 9750 Dash
Water 92 C Dash
Air_T 40 C Dash
Boost 17 psi Dash
Old Feb 22, 2006 | 09:40 PM
10sec rx7's Avatar
be VERY carefull using those T_MAP settings....
Old Feb 23, 2006 | 02:13 AM
boostin_7's Avatar
what do you suggest for the t_map setings dale?
Old Feb 23, 2006 | 04:36 AM
10sec rx7's Avatar
at 10psi on our fuel here something around -12 depending on intercooler and turbo setup
Old Mar 6, 2006 | 04:56 PM
jimmyv13's Avatar
Round&Round not Up&Down
No kiddin....your boost timing is REALLY advanced. At 12 PSI, I have -12 and it goes in pretty much a straight line down to 2 PSI which is at 0.
Old Apr 25, 2006 | 07:02 AM
boostin_7's Avatar
are these values ok to put inplace of the ones in the above quoted map:
10psi - -12
8psi - - 9
6psi - - 6
4psi - - 3
2psi - 0
what about the 00"hg to 30"hg values are they correct in the above map?
Old May 18, 2006 | 05:18 PM
DrifterS4's Avatar
Hey Raton Is that with a mt8 or lt10 system, does it really matter or are both systems the same. I am jsut curious because i am in the process of trying to tune my car. I have an LT10s with the bosche coils. Will your settings work? Thanks.
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
