Tension bolt sleeve?
Old Feb 20, 2006 | 09:45 AM
7-sins's Avatar
thats not paint....
I wire-wheeled my tension bolts for the rebuild and there was like a 1/2" sleeve on the center of one of the shorter bolts. Is this needed? I checked mazdatrix and didn't see anywhere to order a new one on their tension bolt section.
Thanks,
Chris
Old Feb 20, 2006 | 11:07 AM
now's Avatar
now
its for vibration, the one that runs on the out side.
matt
Old Feb 20, 2006 | 02:03 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
you can use a bit of heat-shrink for it.
Old Feb 20, 2006 | 02:18 PM
now's Avatar
now
or just gob some silicone on it after you put it in and tighten it up
Old Feb 20, 2006 | 07:57 PM
or both if you have s4 tension bolts.
Old Feb 22, 2006 | 06:22 AM
RETed's Avatar
You don't need it.
-Ted
Old Feb 22, 2006 | 12:02 PM
pistonsuk's Avatar
Originally Posted by RETed
You don't need it.
-Ted
Why not? What was it put there for?
Justin
Old Feb 23, 2006 | 06:34 AM
RETed's Avatar
That outside tension bolt?
If you look at it, that plastic sleeve lines up with the center housing.
Me thinks it's just for a snugger fit to the center iron.
If it was for some kinda fancy vibration issues, why don't all of the tension bolts have them?
They don't.
All I know is that the blasted sleeve makes it a PAIN IN THE *** to remove the used stat-o-seal washer! :P
-Ted
Old Feb 23, 2006 | 07:10 AM
dubulup's Avatar
development
I put heat shrink on all the tension bolts...(middle threads)
Old Feb 23, 2006 | 09:01 AM
RETed's Avatar
FD owner, right?
FC 86 - 88 didn't have those "grooves" in the center of the tension bolts.
FC 89 - 91 did.
At least this holds true for the 13BT's...
All FD 13B-REW's run those grooved tension bolts.
-Ted
Old Feb 23, 2006 | 09:35 AM
now's Avatar
now
They don't.
-Ted
ted i am surprised i thought you knew everything
I would say the coolant keeps the vibration to a minimum on all but a couple.
fluid is good for vibration dampening.
matt
Old Feb 24, 2006 | 12:17 AM
RETed's Avatar
Well, I was going to keep that fact as an ace up my sleeve, but you beat me to it.
-Ted
toplessFC3Sman
Mar 20, 2018 01:54 PM
doritoloco
Oct 1, 2015 08:03 AM
Vartok
Sep 24, 2015 02:20 PM
