Microtech help whit timming
Old Feb 15, 2006 | 02:55 PM
JJSRX7's Avatar
Newbie
Cool help whit timming
I have a 93 rx7 series 6 whit the two timing pickups in the front I need to know if I put a timing light on the front pulley and I lock the timing on the Micro Tec what will the timing light read the reason for this is that my front timing plat is slotted and I can move the timing forward or backwards the same as a distributor
normal you will not do this as its fix on the series 6 I have install MSD on the car and it looks like the timing has moved by 9 deg.
Old Feb 16, 2006 | 07:12 PM
myfc3s's Avatar
That's what she said...
It should catch the timing if you do put it on "LOCK" use an inductive timing light if you can. Dont forget to "UNLOCK" when done..
dona1326cosprings7
Oct 29, 2015 06:47 AM
Barrman
Sep 3, 2015 07:59 PM
morataya
Microtech
Aug 16, 2015 09:39 AM
sypath
Aug 16, 2015 12:06 AM
