I want to see DYNO slips of NA TURBOS! & TII high comp
Old Feb 11, 2006 | 01:29 PM
iceblue's Avatar
Passing life by
I want to know if I am right or wrong. So I am calling the group to post all there slips of your NA turbos and turbos with NA rotors. There is allot of claims out there and allot of logic of why a NA system can not create power. I want to diminish the misunderstandings and logics and prove one of them.
Please post your mods with the slip.
Old Feb 11, 2006 | 02:10 PM
DemonicPupil's Avatar
AutoX Donut Maker
Let me ask an interesting question about dyno slips while there's a thread here. Do I need to purchase my own wideband sensor and etc. when going to do a dyno tune, or do the dyno shops usually have one? Sorry, seems like a stupid question, but would love to know.
Old Feb 11, 2006 | 02:12 PM
jm93rx7's Avatar
Committee Member #3
most dyno shops have it
classicauto's Avatar
Crash Auto?Fix Auto.
True, but its also common practice that you would have your own........just like in this case........get your own thread! (joking but serious)
Old Feb 11, 2006 | 02:20 PM
iceblue's Avatar
Passing life by
The dyno has one its also called a hydro stat sensor. This is how the dyno displays its results of AFR's.
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
it's dyno SHEETS and time SLIPS!!!
PS I dont think youll get many replies at all. You'll have better luck probably searching in the Timeslips/dynosheet forum
Old Feb 11, 2006 | 04:08 PM
AutoX Donut Maker
next time I'll make an extra thread then =P...
iceblue, as soon as I get mine all together, I'll get it dyno'd and post.. NA turbo.
Old Feb 12, 2006 | 09:50 AM
Aaron Cake's Avatar
Engine, Not Motor
I never got a dyno with mine since dyno day got cancelled. And dynoing my new setup will probably produce results that are skewed a little higher then typical basic NA turbo setups. Regardless there are plenty of turbo-NA 1/4 miles runs in the archives from which you can calculate a HP value.
Old Feb 12, 2006 | 11:27 AM
iceblue's Avatar
Passing life by
This also has to do with a private conversation with Jrat. No one posts numbers and it seems allot of people feel that NA boosted can’t produce over 300hp. I disagree and say they can produce exactly the same amount of power. And with smaller turbos and less boost. If anyone has read the other thread about this its also been said that high comp cant work b/c of overheating and other stuff. Another one that ahs been brought up is that the volumetric efficacy of a high com setup can’t produce the power of a low comp. Again why do no top racers run high comp and why does the factory install low comp on turbo setups? Do they know something we don’t?
Like I said I am trying to dispel this information.
Old Feb 12, 2006 | 11:35 AM
88rxn/a's Avatar
tom port.. AKA streetport
i think everyone gets scared because of the high compresion...
as for me... im shooting for the 300 mark only because i have a dual friction clutch and dont think itll take much more than that with a n/a tranny without slipping or breaking somthin... later ill go with a bnr stage 1 or 2 and see what happens after i get my setup i currently have going now going decent... ill try to get some numbers this summer
Old Feb 13, 2006 | 01:39 PM
Aaron Cake's Avatar
Engine, Not Motor
Honestly, who cares? Let them think what they want. Much better things to use your energy on (as I learned several years ago after getting in the 10,000th argument about it).
Old Feb 13, 2006 | 01:49 PM
jacobcartmill's Avatar
just dont care.
turbo NA's are slow and in pieces
ask aaron cake :x
Old Feb 13, 2006 | 07:41 PM
stacher's Avatar
ask aaron cake :x
Have you own one? Didn't think so! So, that must be your OPINION.
I get it...... you are just joking.
Old Feb 13, 2006 | 07:45 PM
SonicRaT's Avatar
Super Raterhater
ask aaron cake :x
lol, this coming from a guy can't top a car with 210k miles and a HYBRID!
Old Feb 13, 2006 | 07:48 PM
just dont care.
doesnt your car get like 62mpg too, mr sorenson?
Old Feb 13, 2006 | 07:50 PM
SonicRaT's Avatar
Super Raterhater
That'd be 32, and that'd be a different car too.
just dont care.
oh, ok.
Old Feb 13, 2006 | 07:51 PM
SonicRaT's Avatar
Super Raterhater
Which is also faster than you now, just incase you're wondering.
Old Feb 13, 2006 | 08:09 PM
13bdarren's Avatar
I just bu ilt a bp turbo na engine. I plan to run a t04b turbo with megasquirt. Won't be able to get a dyno runs in till spring.
Old Feb 13, 2006 | 08:43 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
they should make more tq ealier by definition, but not more overall peak power.
effective compression is effective compressoin, with a 8.0:1 slug and 20lbs or a 10:1 with 6 lbs, you can only have so much chamber pressure, only so high of egt's etc etc
and for the record, the #'s i used were just to make a point, no truth to them,
Old Feb 13, 2006 | 08:53 PM
an 8.7:1 cr motor running 1 bar has an effective comp of 17.4:1 (easliy done on pump gas)
a 9.7:1 cr motor only has to run 11.7lbs to have the same effective CR
With the lowe ramount of booost, intake charge tempetures are lower, smaller turbo can be utilized which can translate into a quicker spool, and a faster car etc etc
-Jacob
Old Feb 13, 2006 | 09:58 PM
SonicRaT's Avatar
Super Raterhater
You run into a situation where you reach a point where your engines temperature rise prevents you from making more power (or running more boost). At this point, you're making considerably more power than a lower compression engine running the same boost, however, if you crank up the lower compression engines boost and near the same power as the higher compression, you then reach a point where if your turbo is still efficient, you can run more boost (and hit a higher effective CR, since the turbos temperature rise is less than the engines at that point), and make more power. Where this threshold is depends on the way the engines built, tuning, equipment used, etc. As companies continue to develop parts, they can withstand this and work within this a lot better, thus why companies are increasingly running more compression on their turbo engines.
Old Feb 14, 2006 | 03:07 AM
eriksseven's Avatar
Make Money.
I'm dyno'ing my '87 TII on Sunday with 9.4:1 N/A rotors. The mods are pretty basic for now:
mild intake/exhaust porting
s4 high-compression rotors
2.5" Bonez DP/MP bolted to Apexi N1 exhaust
Walbro 255
750cc secondaries
R-Tek 1.7 chip
stock turbo/TID running 13psi via Profec-B
I'm hoping for around 230whp.
Old Feb 14, 2006 | 03:14 AM
SonicRaT's Avatar
Super Raterhater
With decent AF/R's you should be higher than 230, probably closer to 260.
Old Feb 14, 2006 | 03:23 AM
chuck8313BTSDS's Avatar
http://groups.msn.com/ChucksRX7/1983...to&PhotoID=104
http://groups.msn.com/ChucksRX7/1983...to&PhotoID=109
Here's a dyno and a time sheet (right lane) for 9.4 rotors running boost.
car was a 1st gen at 2720lbs during the IDRC event.
chuck
