Microtech microtech weird
Old Feb 8, 2006 | 05:14 PM
kd86rx7's Avatar
microtech weird
it was going good before, the car turned over stayed on. but after a little adjustment it wasnt able to stay on again. so i put it back to the base map according to the sticky from silverrotor above. then i dont know why, so i put it in test mode, i heard a pop in the engine bay, i got spark and fuel, i took it out of test mode and back to 4 cyl. but now when i turn the car to idle i get both the green and yellow light, the yellow only turned on when i cranked the car to show ignition, but its a constant yellow light with the key to on position. i dont konw y. i calibrated my tps, i saw the asterisk (*) at +1% +2% and +3%. so i use the middle. i dont know why now the yellow light is constantly on.
eric.
Old Feb 8, 2006 | 09:44 PM
10sec rx7's Avatar
cause it is not getting a signal from the CAS,
check your wiring
Old Feb 9, 2006 | 02:13 AM
kd86rx7's Avatar
good thing is that my car starts again when i chagned my spark plugs, but when my key is on "on" position the yellow light is always on with the green light, and when the car is started, it flashes, so i guess its fine now. thanks 10sec rx7. always responding to help fellow microtech-ers.
eric.
Old Feb 9, 2006 | 02:16 AM
kd86rx7's Avatar
kinda off topic, but i set my tps to 1k ohm resitance like stock. then under tpscal i adj until i see teh asterisk (*), if seen three pick the middle right? mine was at +1%, +2%, +3% so i pick +2% right?
eric.
Old Feb 9, 2006 | 06:24 PM
Spooledup300z's Avatar
Yah pick the 2% although i dont think it really matters, as long as you see the * your tps is cal
LongDuck
Oct 7, 2015 08:12 PM
JoesFC
Oct 5, 2015 08:10 AM
Devon Murray
Sep 26, 2015 08:15 AM
freq
Haltech Forum
Sep 13, 2015 07:45 AM
