Megasquirt Resistors
Old Feb 8, 2006 | 04:43 PM
lowkee33's Avatar
Slo Low
Resistors
Where exactly do I put my 3 4.7 k pull up resistors for the L.E.D.'s?
Old Feb 8, 2006 | 05:06 PM
muythaibxr's Avatar
MegaSquirt Mod
they should go from a +5v source to the negative lead of each of the LED's... I'll see if I can find a pic later.
Old Feb 9, 2006 | 08:52 PM
lowkee33's Avatar
Slo Low
do they go on top of the pcb or bottom.
Old Feb 9, 2006 | 09:38 PM
renns's Avatar
I ran my set flat against the board along the front edge, below the led's. The legs were bent to attach to the 5v side of the led resistors, and then the opposite side of the led's. I've attached a board pic of a similar install, taken from http://megasquirt.sourceforge.net/ex...tup-gmdis.html. I'm not keen on the mounting arrangement shown, as the resistor standing up as shown will be more susceptible to damage and vibration, but it certainly shows the connections clearly enough.
Old Feb 9, 2006 | 11:23 PM
muythaibxr's Avatar
MegaSquirt Mod
on a v3 board it'll be slightly different. I will have to take a pic as it appears that I don't have any.
Old Feb 10, 2006 | 10:50 PM
lowkee33's Avatar
Slo Low
I really appreciate the help you guys have given me.
Old Feb 10, 2006 | 11:55 PM
KeloidJonesJr.'s Avatar
strictly business
right on
Old Feb 11, 2006 | 06:27 AM
Rex4Life's Avatar
RX-7 Alumni
Yea there's a lot less space on the V3 board. I did my resistors like the pic in the faq but ran the wires from the bottom side of the board.
If you look close at the pic, you can see I made a little loop on the bottom side of the board and soldered the wire into it.
Old Feb 11, 2006 | 12:14 PM
lowkee33's Avatar
Slo Low
Did you mount yours in the stock computer box? Also thankyou for the pic and the help. One last question was the adapter you made for the harness to make it plug n play hard to make. I already have the plug from an ecu ad wires. Is there anything I should know before I do it?
Old Feb 11, 2006 | 12:42 PM
Rex4Life's Avatar
RX-7 Alumni
Yes it's in the stock ECU box--there's another thread all about it with pics.
It was alot of work, but I suppose if I started building more it would be easier--but still alot of work.
I'd recommend running all the CAS wires in shielded pairs. I'm in the process right now of re-doing those 4 wires with shielded.
kuuva86
Sep 28, 2015 05:42 AM
FC_DREAMS
Sep 9, 2015 06:24 PM
