Sponsored by: CARiD
anyone put sparkplug in exhaust system to make BIG ass fire?
Old Feb 3, 2002 | 02:42 PM
anyone put sparkplug in exhaust system to make BIG *** fire?
Im just curious about how u do that............It looks cool
Old Feb 3, 2002 | 10:43 PM
noodle's Avatar
ur wreckin my set
you have to hook up an igniter and some other stuff, the first time i heard of it, hell i thought u just thru one in the exhaust and that was that!
Old Feb 3, 2002 | 11:47 PM
wonder1and's Avatar
I Sold My Car 2 the Devil
Auto Exhaust Flame Thrower by The Jolly Roger
For this one, all you need is a car, a sparkplug, ignition wire and a
switch. Install the spark plug into the last four or five inches of
the tailpipeby drilling a hole that the plug can screw into easily.
Attach the wire (this is regular insulated wire) to one side of the
switch and to the spark plug. The other side of the switch is attached
to the positive terminal on the battery. With the car running, simply
hit the switch and watch the flames fly!!! Again be careful that no
one is behind you! I have seen some of these flames go 20 feet!!!
-------------Exodus------------
"I can't recall the exact location that I found this document, it may have been in some sort of cookbook... hmm...."
Ryker
Old Feb 4, 2002 | 02:25 PM
SwwwwwwwweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeT!!!!! !!!!!
When im done.. i'll post some pictures
Old Feb 9, 2002 | 02:34 PM
Nathan Kwok's Avatar
LOL. I don't think just a spark plug will do it. Its going to be tough to get a spark across the gap with 12V don't you think? You'll need an ignition coil as well.
Old Feb 9, 2002 | 06:12 PM
RotaryKnight's Avatar
Ah the old glow plug trick.. I heard that you should use the plugs from a diesel motor. The plugs are different and will heat up and stay on or something like that.
Old Feb 9, 2002 | 07:16 PM
Hmm.. i still wanna do it
Old Mar 24, 2002 | 08:06 PM
spectre225's Avatar
Use a 12 volt coil to provide the spark for the
plug. Works great for throwing flame 15 to 20 feet
and for getting you thrown in jail. I speak from
experience.
Old Mar 24, 2002 | 11:48 PM
rerx7's Avatar
I saw a story about this in early issue of Motortrend or road & track.
Old Mar 25, 2002 | 02:38 AM
menace's Avatar
why bother? a 3" exhaust system will do it just fine....
Old Mar 25, 2002 | 11:20 PM
vadym's Avatar
i tried this setup, but i got no spark. connecting the coil to battery and the switch wont do it. How do i triger the coil, what do i connect it to?????
Old Mar 26, 2002 | 01:20 AM
MasteRX's Avatar
More Than Meets the Eye
Coils will only discharge their spark when the power is turned off. So you turn on the switch to charge and turn off to discharge the spark. By the way, you dont have to charge the coil for long, only about 1/40000 of a second will charge it enough.
Old Mar 26, 2002 | 09:47 PM
vadym's Avatar
so can get a relay or something the will switch by it self?
Old Mar 27, 2002 | 12:13 AM
flubyux2's Avatar
Thats not an FC...
hook up a GM HEI distributor in your car.
it has the convenient coil in cap, so less wires. just run a heater blower fan, hook the out put of the heater fan to the drive shaft of the dristributor. hook up the power and ground wires on the coil, and you can run as many as 4 wires per plug if you have 2 tail pipes.
i had 2 GM points coils, spark plug wires, and a switch to turn the coils on and off. just ran power from the batterey to the switch, splite to the 2 points coils, and then chassis grounded the other primary side of the coil. then when you flip the switch on, it charges the coil, when you turn it off, it sparks. i went to Walmart, and got the spark plugs that had the MOST threads so theyd stick into the pipe as far as possible, and tack welded them in.
this was on my 79 trans am. i had a kill switch for my ignition coil. so what id do is rev up my engine, hit the ignition kill switch, floor the throttle (or pump it) then flip the coil power switch on and off as fast as i could. after about 4 or 5 flips, it would sound like a HUGE oxy-acetelyne or Propane torch lighting up, and the flame burning would sound like a huge torch. so "PFFFFFFFFF, hhhhhhhhh, POW!", the engine rpms would fall off, the flame would get smaller, and then recede into the pipes and Backfire like a gunshot, but not always. my sister watched it and said it was blue, like a jet flame, about 2 or 3 feet. 2 or 3 foot flames arent bad if youre shifting, but sustained for 30 seconds while coasting down the freeway is Indescribable. no one would tailgates after seeing that.
have fun.
chris
Old Mar 27, 2002 | 10:13 AM
vadym's Avatar
You lost me. is there an easier way?
Old Mar 27, 2002 | 07:58 PM
Dyre's Avatar
Your Opinion is Wrong
Full Exhuast + Rotary + Running Rich = flames.
cristoDathird
28
May 30, 2019 08:47 PM
succesfulljoe
Aug 20, 2015 08:59 AM
