94 RX-7 Track Car Project Begins
Injected with a Poison
on
Here is a 1994 White Rx7 Purchased to build a Track car for NASA and SCCA events. I will Post Pics as the progress continues. Any Input or sugestions will be greatly appriciated. I will also be parting out the complete interior along with the OEM Hood and Trunk.
on
Im doing the same exact thing ( in miami too) with a 92, and all I can say is exepect to double your estimates of how long it will take if you plan on doing a real thorough job. I'm about a year and a half into my project, and still have a few more months to go.
good luck man!
good luck man!
COOL
Few advice for you for building a Track only car
What class you plan to run. There are big different between A Race CAR and a Time Attack and Solo2 car. Plan ahead
how much money you plan to spend. A lot of time I seen a lot of people spend too much money on buying parts, but end out give up the project!!, For me most important thing of RACE CAR or Track car is to drive on Race Track.
I think FD, The only class legal in SCCA is. GT-2 or 3 but you cant run turbo in that class, plus there are very little change to against to real GT car(tube frame). there are one class call ITE, this is regional only class, but most of mod is allow in this calss. so in this class you see some very wacky race car or some very very fast one.
NASA is about the same thing only unlimit class for Turbo FD.
For Solo2 you can build a BP car ? I am not sure is FD is legal or not
Time attack car. since time attack is getting popular right now. so it would nice to see FD doing it.
As I said before. money money money. how much you want to spend. and Driving on Race track do wear you car a lot !!!!.
MY Road RACE FC. was plan to build as Turbo 13BT. but change to EFI 13BPP. and last to 58 IDA 13BPP.
Trending Topics
Slam Pig
on
Man I cant wait to get another rx7 someday
Tips for projects...
Make lots and lots of lists
Start with very open lists then form them down into more specific lists
Schedule time to work on the car 10-6 on saturdays works for me and my buddy
Do not get overwhelmed
Start off small, like alot of guys are saying driving is more fun then turning a wrench. Figure out what you can get done with the time your allowing yourself and tear it down the following season.
Seriously the list technique is key..having a game plan before you do things is helpful and crossing things off helps you feel like your getting somewhere
As others have suggested determine which class you plan to race in BEFORE you begin any planning/building.
I race in NASAProRacing TimeTrialUnlimited. My car is a street car that I take to the track about 1x month (hopefully that often this year). If NASA is in your area check them out. There are some 700hp+ 2500lb cars in my class and only a handful of seconds faster.
MM
Tilton pedals.. Haltech. IDA ITB. Dry sump tank... interesting !!. I guess this would be NA right? Bridge or PP ? GT OR ITE ?
oh BTW you would need two of that oil cooler to cool your project car. you oil cooler should aleast cool 1/3 of your engine heat. so in other way. it migh better if your oil cooler size is 1/3 of Radiator. This is how I did on my 13BPP. before I have oil temp too hight problem.
And last, you might not want to use OBX harness.... it might look the same. but is hard to tell this thing will hold under accident... so better buy one with FIA or SFI aprove...
Good luck on the project
J
J
on
Here is an update, The Car was finished today, Just as the fabricator Prommised (9 Days). This guy is out of hand with his work. His welds are even and artistic the way he bends the tubing to truly follow the inside contour of the car. I have seen a couple roll cages that have been done. This guys work surpasses them all. A little pricey, but you will get what you pay for. I dont know anyone else that was able to get all this work done in that amount of time. AND it still look this good
Install 8 point roll cage through fire wall onto front struts
Driver and passanger Nascar style side protection
Mount Pedal assemblies
Mount sterring Column
Remove Factory Driver side floor pan and make new base for race seat and brackets
Mount 4 Gallon Dry sump Oil Tank behind poassanger seat
Mount Tabs and brackets for 5 point safety Harness x2
Mount 22 Gallon Fuel cell
Cromoly Tubing through out
Weld mount tabs all around the sunroof and Install lexan with black border for sunroof
Total = 4100.00
Total = 4100.00
OBEY YOUR MAZDA
Wow looks nice.
I still cant believe its legal to mount the dry-sump tank inside the car.
We are not even allowed to have a mechanical oil pressure gauge in the cabin.
But then again FIA and SCCA arent the same
Keep the pics coming.
Kim
Kim
Racing is life!
on
Originally Posted by Kim
Wow looks nice.
Kim
Kim
Looking good.
