For those with ideling problems,i found it !
Old Feb 2, 2002 | 07:37 PM
Without tearing everything apart,first i researched as much as i could
about ANYTHING rough idel,,searching mazdatrix site,found a "how-to"
section.In that section the topic is "coasting valve" shows how to test,
I test my 7 ,,and it was right on the money,,it was sucking air BIG.
now i know to get a new decel. "coasting" valve,, BTW,,,
my plugs,wires,cap/rotor,fuel filter,and spark were all ok,,too,,,nailed that MF
Old Nov 1, 2011 | 08:20 PM
FB331's Avatar
I checked this out right away and concluded two things 1. My coasting shutter valve whatever thingy is pooped 2. It seems like and absolute pig sty to try and fix myself?
Old Nov 2, 2011 | 11:47 AM
j9fd3s's Avatar
Community Builder
its actually easy. you unbolt the carb, and swing it out of the way (no need to disconnect anything i think), and then its right there. its really a 15 minute job.
Old Nov 2, 2011 | 03:36 PM
Kentetsu's Avatar
Locate the arm that controls the movement of the shutter valve, then wire it open?
ZacMan
Sep 19, 2015 09:20 PM
NotMrButts
23
Sep 15, 2015 09:46 PM
vmerino
Sep 5, 2015 11:26 AM
