Microtech Microtech trouble
Old Jan 30, 2006 | 06:26 PM
Johny zoom's Avatar
Microtech trouble
My car has been down for a couple of weeks to fix a couple of problems,(oil leak) Now Im getting no spark at crank, but I get spark an test mode I tried a cas and spun it still no spark,
Any advice
Thanks
Johny
Old Jan 31, 2006 | 04:32 AM
10sec rx7's Avatar
check the wiring to the cas, if it is not working when spinning something is not right there,
if it sparks in test mode then its not the wiring to the coils
Old Jan 31, 2006 | 05:33 PM
Johny zoom's Avatar
UPDATE!!
I found a frayed wire on the CAS I replaced the connector. I got the car to fire but it runs awful it shut down and now doesnt want to start I was getting a lot of smoke (smelled like unburnt fuel also A/F was about 9 on wideband. Im getting spark on test and crank, but something is wrong. Both coils are firing under test.
The car was running fine. I took it out of service fixed an oil leak replaced turbo gasket, and oil pan. Removed alternator and pulleys for powdercoating, I did not remove CAS. I installed the alt It was not charging so I replaced it with the original I installed everyting back and this is the result.
Please help I have not made any changes other than test mode with the hand set
Please tell me where to start
Old Jan 31, 2006 | 06:29 PM
10sec rx7's Avatar
change the spark plugs
Old Jan 31, 2006 | 06:46 PM
Johny zoom's Avatar
Already did I installed 9's Im going to get 7's and 9's tomorrow
Thanks any more Ideas
Old Feb 1, 2006 | 05:52 PM
Johny zoom's Avatar
UPDATE.
I got the car to run after installing plugs. It still is running rich as hell. I took a ride A/F was around 9 or ten even while coast down, Im hearing engine interference in the radio for the first time. I going to reground everything and also change plug wires.
Johny
FC3S Timmy
16
Oct 3, 2015 01:08 AM
Rotafuzz
Sep 30, 2015 09:55 AM
Red-Dragon_Akuma
Sep 28, 2015 06:09 AM
freq
Haltech Forum
Sep 13, 2015 07:45 AM
