J-Bridge
Old Jan 29, 2006 | 11:48 AM
BRIDGEP0RTED's Avatar
J-Bridge
Once the groove is cut how would you go about sealing off coolant?
Old Feb 1, 2006 | 06:04 AM
karism's Avatar
Adolf Hitler Verfechter
Well,i would normally use allot of RTV sealant ,after blocking off the water passage at the intake port completely.What year is the housings yuor using?
Old Feb 1, 2006 | 03:37 PM
C. Ludwig's Avatar
www.lms-efi.com
Devcon
Old Feb 1, 2006 | 06:22 PM
s4 or s5 13b
Old Feb 7, 2006 | 04:44 AM
karism's Avatar
Devcon,or a material similar to it will work best.Go about it the same way as the guys who build PP engines,by blocking the water passage in the rotorhousing completly.Depending how well you seal it will be directly converted to how long before the engine start seeping water into the combustion chmabers,so take extra care when doing it..
karis
Old Feb 11, 2006 | 05:14 PM
ok i have heard or some using apex seal springs and side seals to keep the coolant seal back. What the groove is ported all the way out would you need to drill a small whole in the groove and cut the coolant seal and have something go through the seal and into the hole with some rtv
karism
32
Dec 15, 2008 06:25 PM
autofanatic_rx7
23
Feb 1, 2006 03:35 AM
DriveFast7
Oct 30, 2003 11:01 PM
