How much HP can FB rear end handle
Old Jan 25, 2006 | 11:54 PM
aussiesmg's Avatar
Thunder from downunder
Cool How much HP can FB rear end handle
With a small block how much RWHP can the GSL rear handle before she's gonna *****.
For those with actual experience with small block engines please.
Old Jan 26, 2006 | 01:43 AM
FCdemon's Avatar
3rd gen junkie
My friend's GSL-SE rear end breaks regularly with 300WHP and slicks at the track, and that is with a turbo rotary (way less torque). So, if you're planning on having good traction and good power at the same time, with drag launches, then you'll need to go to something beefier. I believe someone sells a kit to drop in a 9"... that's what I heard, anyway.
Old Jan 26, 2006 | 05:36 AM
Brismo7's Avatar
6 Speed FC
there is a guy over on toque central with a 383 SBC running mid to low 12's all day long on a stock LSD Rear end in his 83 FB. V8's are better for the rear end then rotarys. simply cuz you have much more low end torque, you dont have to rev to 9k RPMs and drop the clutch, thats why your buddy keeps on breaking his.
my FB, anything more than 1/4 throttle, and i just start smoking the tires.
~Steve
Old Jan 26, 2006 | 05:16 PM
FCdemon's Avatar
3rd gen junkie
I think it's more that he is hooking up well with slicks... with street tires on he never breaks anything.
Old Jan 26, 2006 | 05:58 PM
perfect_circle's Avatar
thats what hes saying 9k + sticky tires apposed to 3500 rpms...
Old Jan 26, 2006 | 07:22 PM
FCdemon's Avatar
3rd gen junkie
what I'm saying is that I don't think the RPM matters.. what matters is how much torque goes through the driveshaft, how much grip there is, and how jerky the power delivery is.
Old Jan 26, 2006 | 07:53 PM
aussiesmg's Avatar
I'm looking for curcuit racing purposes mainly, so wont be using drag slicks....
Old Jan 26, 2006 | 10:23 PM
Nihilanthic's Avatar
moon ******
Even with slicks, circut racing youre not going to be shocking and megaloading the driveline... so I wouldnt worry
Old Jan 26, 2006 | 10:51 PM
Swolbynos's Avatar
Newb
i twisted the axles in my GSL-SE with an open header. 8k drop at the drag strip.... checked the driveshaft and wheels, so it was somethingin the rear end
had rear end vibrationbad enough to make your *** go numb
Old Jan 26, 2006 | 11:57 PM
turbojeff's Avatar
Do it right, do it once
I had a friend with a ~275hp TII motor in his FB, he couldn't get the rear ends to last long with heavy usage. They would get noisy and then self destruct.
Old Jan 29, 2006 | 05:16 PM
vxturboxv's Avatar
Depends if you are useing an auto or a manual trans as well... www.grannysspeedshop.com is a good place to find info on that.
Old Jan 29, 2006 | 06:50 PM
moon ******
If youre circut racing you wont be loading it like a clutch dump on slicks at a drag strip would.
In other words... dont worry, unless you DO dragrace.
Old Jan 29, 2006 | 08:37 PM
520hp@26lbsRX-7's Avatar
Bosozoku
If your worried about breaking your rear end, I have a narrowed ford 9", if thats the way you want to go.
Old Jan 31, 2006 | 01:44 AM
FB II's Avatar
~Steve
i believe he's actually running low 11's, just shy of a 10 sec 1/4 on the stock rear end and stock wheels!!!
350hp/360tq to the wheels. i'll try and find the video of it. good stuff i tell ya
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
