Setting Up A Distributor
Old Jan 13, 2006 | 09:44 PM
01Racing's Avatar
Go Hard....or Go Home
Does anyone have any experience locking a distributor for a 13B? I need to get instructions on how to cancel out the vacuum advance
Old Jan 14, 2006 | 08:48 PM
wecycle's Avatar
advance
Why?
If you remove and plug the vacuum lines to the L & T vacuum diaphrams you will disable the advance.
Old Jan 16, 2006 | 12:04 PM
01Racing's Avatar
Wouldnt the centrifical weights still move inside the distributor?
Old Jan 16, 2006 | 02:28 PM
rotarygod's Avatar
Rotors still spinning
Yes but mechanical advance and vacuum advance are independent of each other. Vacuum advance is only there for added low end/part throttle advance for economy reasons. Vacumm is lower at full throttle so it isn't really doing anything at full power. Just disconnect the vacuum lines. Leave them uncapped on the distributer side though. Only plug the engine side of the vacuum line. There are threads here somewhere that show how to "lock" the distributer.
Old Jan 17, 2006 | 07:20 AM
REVHED's Avatar
Hunting Skylines
Easiest way to "lock" the dizzy is to remove the springs from the advance weights.
matty
Jan 18, 2020 10:39 AM
dludden
Aug 26, 2015 11:25 AM
Joe428
16
Aug 19, 2015 06:24 PM
