(IGNITION) Improved FB Coil-DLIDFIS Wiring Diagram
Old Feb 29, 2004 | 01:15 AM
vipernicus42's Avatar
Rotoholic Moderookie
Hey Guys,
I took Jeff20b's DLIDFIS wiring diagram and actually put the names instead of the numbers. Jeff gets full credit for the diagram, I just replced his numbers with names to make it easier to read.
If a mod could place this in the locked DLIDFIS thread in the Archive, or move this thread to the archive that might help.
Jon
Old Feb 29, 2004 | 02:08 AM
Jeff20B's Avatar
Lapping = Fapping
Very cool!!
Yeah, I whipped it up in MS Paint one day. It was based on one I made before. I only showed the very basics, and added a 'legend' in HTML text below it.
I've been thinking about upgrading it a little here and there, but no need right now; you've done a great job.
Mods, please archive this or something.
Old Feb 29, 2004 | 03:00 AM
mazdaverx713b's Avatar
Have RX-7, will restore
Very awesome!! Wish it was that easy from the start! Great job to you both!
Old Feb 29, 2004 | 03:59 AM
riceburner1r2001's Avatar
dfis
still looks confusing and why 3 coils for a gsl-se oh well i guess i will have to figure itout myself
thanks anyway
Old Feb 29, 2004 | 12:32 PM
3 coils - Leading for Rotor 1, Leading for Rotor 2, and the Trailings fire at the same time off of one coil
Jon
Old Feb 29, 2004 | 01:36 PM
mwatson184's Avatar
holley guy
^close, but not quite right.
The leadings fire at the same time. Each coil is firing off the same source. The trailing runs through the dizzy as it does normaly.
-Marques
Old Feb 29, 2004 | 07:07 PM
Damn... I guess I'm not ready for my DLIDFIS course diploma yet... Back to the books for me!
*picks up a sixpack of JOLT cola and goes back to study hall*
Jon
Old Feb 29, 2004 | 08:10 PM
Siraniko's Avatar
RX for fun
In the above diagram, you can add a kill switch as an upgrade to DLFa;fja;fj.
You can run a wire directly from the battery to a 30 amp relay (fog lights). this will supply juice to both leading coils, as well as the trailing.
And finally, to energize the 30 amp relay, run a wire from the ignition then to a switch then to the relay (this is the low voltage) to energizze the relay.
Just be sure to hide the switch somewhere. Instant kill switch.
Old Feb 29, 2004 | 08:26 PM
Matty's first 1st Gen's Avatar
Boosted 7
I have heard alot of people powering DLIDFIS through a relay directly to the battery, How much of a difference would this make? Maybe a slightly better high end spark. or is doing this not worth my trouble?
Old Feb 29, 2004 | 09:11 PM
mwatson184's Avatar
holley guy
^that is how i have mine wired. Ignition switch to relay. The relay runs from the battery to the positive on the coils. Makes for a nice clean install, and gets rid of a lot of the factory wiring.
-Marques
Old Feb 29, 2004 | 09:38 PM
Jeff20B's Avatar
Lapping = Fapping
My white REPU needs a relay because the nearly 30 year old wires to the key get kinda hot. I already hooked up a relay in my other REPU and it actually cured a blip at idle, and the wires barely get warm now. Highly recommended.
I wonder if it'll cure the occasional blip in the white REPU's idle? Couldn't hurt to find out.
Old Mar 1, 2004 | 12:02 AM
Siraniko's Avatar
RX for fun
Thats how I did my RX-3 (but now im running MSD since i got it for xmas 2 yrs ago), my bro's SA and several others FB's. it worked good and its a kill switch too. maybe I will write a diagram when I find the time.
Old Mar 3, 2004 | 11:26 PM
Sorry to bring this back from the 2-week dead, but when talking about the relay from the battery....
You mean skip the ignition switch entirely, just go battery-relay-coils
instead of battery-ignition switch-coils
What kind of relay? (Hell, I don't even know what a *relay* IS!)
Lost In DLIDFIS Study Hall Again
Jon
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
