ECU help
Old Jan 27, 2002 | 12:15 AM
rx7newbie_2001's Avatar
Question ECU help
So if I get a m2 ECU for my mods I would just send them mine and they reprogram it? After I recieve it I would just install it and thats it. plug and play?? Would this be the same for a power FC? I dont know anything about programming it. thanks for any help
Old Jan 27, 2002 | 07:35 AM
jamie1171's Avatar
Go with the Power FC from Ray at S2. He will pre tune it based on your mods. Its plug and play, the care runs great and the commander is a great tuning and diagnostic tool
Old Jan 27, 2002 | 01:04 PM
would you happen to have an internet address, link to S2?? thanks
Old Jan 27, 2002 | 03:40 PM
Mahjik's Avatar
Mr. Links
Unless you plan on going Single Turbo or running larger injectors, just go with a M2, GForce or Pettit ECU replacement. The install will be much simplier and it's just plug and play. You can take a look at what it takes for intalling a Power FC here:
http://www.scuderiaciriani.com/rx7/p...C_install.html
I'm not sure about M2, but with GForce, you usually need to send your ECU for reprogramming. With Pettit, you can either send them your ECU, or you can pay a CORE FEE and have them send you an upgraded ECU. Then when you return your ECU back to them, you get your CORE FEE back. The core fee for Pettit is $650.
I believe this is the site jamie1171 was referring to: http://www.srx7.com/sr93ecu.html
Erosangel
Sep 18, 2015 10:28 PM
Erosangel
Sep 18, 2015 04:06 PM
