Sponsored by: CARiD
Why does an FD redline higher than an S5 T2?
Old Nov 28, 2005 | 05:37 PM
arghx's Avatar
rotorhead
S5 T2 redlines at 7000, does it not? Why does an FD redline higher? I thought they had the same short block.
Old Nov 28, 2005 | 05:52 PM
slpin's Avatar
7th Heaven
because the FD actaully makes power past 7k
Old Nov 28, 2005 | 09:45 PM
arghx's Avatar
rotorhead
yes but is this because of the turbos or what? The s6 has the same ports, rotors, etc basically right?
Old Nov 28, 2005 | 09:54 PM
RETed's Avatar
13B-REW is built better.
It has tighter tolerances.
It runs at a higher oil pressure.
It has deeper / better bearings.
It has better internal coatings.
Yes, it does have bigger ports.
-Ted
Old Nov 29, 2005 | 12:31 AM
RotaryResurrection's Avatar
But most importantly, you have enough turbo to move enough air to continue to make power on top end on the FD, while the s5 turbo bleeds (loses) boost on top end in stock form. And the FD intake manifolds and ports flow better than the FC ones.
Ted, what "tighter tolerances" do FD blocks run compared to FCs? All the internal clearances are equivalent between the 2. True, the castings on the FD are stronger, but that has nothing to do with tolerances.
The coating on the FD rotorhousings was for longer life, and would have no impact on structural integrity. Same for the coating on the tips of the FD rotors that supposedly allowed less apex slot wear.
Bearings and oil pressure are improved, but the FC oiling system is hardly inadequate for 8krpm anyway.
Old Nov 29, 2005 | 02:39 AM
I wish I was driving!
Acceptable runout of the eccentric shaft is twce as much in the FC compared to the FD. This is all I can think of.
Old Nov 29, 2005 | 03:55 AM
RETed's Avatar
You ever looked up bearings for the 13B-REW?
There's like a dozen part numbers!
How many does the FC 13BT have?
Two!
One = 0, and the other one is oversized like 0.005" or something like that.
-Ted
Old Nov 29, 2005 | 12:41 PM
By your post I assumed you meant seal clearances or something along those lines.
But we have already touched on the oiling system and it is generally agreed that the stock FC oiling system is more than adequate for 8 grand.
I normally see more bearing wear on FD's than I do on FC's despite the more advanced setup, especially when you figure that FC's have more miles on them.
Old Nov 29, 2005 | 09:48 PM
RETed's Avatar
Yeah, sorry, my wording was a bit confusing.
You're right.
The clearances for the sides seals, corner seals, apex seals, etc. are identical.
-Ted
Old Dec 4, 2005 | 03:33 AM
t-von's Avatar
Rotor Head Extreme
Does the turbo Fc have hardened stationary gears like the Fd?
Old Dec 4, 2005 | 05:34 AM
Rxmfn7's Avatar
Do a barrel roll!
As far as I can remember, the S5 cars did, but S4 didnt. Its been a while since Ive played with FCs, so someone correct me if Im wrong.
Old Dec 5, 2005 | 05:50 AM
RETed's Avatar
Kouki FC turbo's come with ion-nitrided stat gears and rotor gears.
I *think* the FD comes with a better coating / hardening.
Yes, both are "hardened".
The FD set are "better" hardened.
-Ted
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Shainiac
Jul 17, 2019 02:20 PM
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
WANKfactor
Sep 29, 2015 01:14 PM
