Canadian Forum Canadian users, post event and club info here.
Help Please
Old Nov 10, 2005 | 05:56 PM
re.fc3s's Avatar
Smile Help Please
I just was wondering if i could get some advice. So currently, i have a 1990 N/A. The engine is good, but to put it simple, i want something more powerful. I am wondering what engine I should look into purchasing. so tII motor was my idea.. but i know the extensive list of things required to make this swap complete**. Not sure i want to do that. Should I rebuild my N/A engine, I heard porting is a good idea to make around 200+, to be honest i dont know what is fully involved wiht this. If anyone can make some suggestions, id really appreciate. Thanks..
Old Nov 10, 2005 | 06:35 PM
im_the_mainevent's Avatar
Cambridge Tire
Exclamation
Go TII but use your N/A driveline with a ACT stage 3 clutch..... i have this setup and am loving it.... alls ya need is ECU , Boost sensor, AFM, and the motor and your good to go.
Old Nov 10, 2005 | 11:06 PM
misterstyx69's Avatar
Retired Moderator, RIP
sorry to jump in..add to question I am thinkin basically along the same lines..so the suggestion is to use a TII engine with a ACT stage 3 clutch ..I get that ..but will the setup be the drive line as N/A..(using N/A trans) or the TII trans..and the remainder the same N/A set-up?..(driveshft down,untouched)..thanks
Old Nov 10, 2005 | 11:25 PM
R.P.M.'s Avatar
Likes to swear....alot
You have to use a N/A flywheel on the Turbo motor to make the motor bolt up to the N/A tranny correctly.
To answer the original question, I've seen some dyno graphs of ported 6 port N/A motors putting down 180 whp using a stock ECU.
Look into using a new Megasquirt for engine managment, it gets rid of the AFM and then you have full tunability. They're relitively cheap too!
Old Nov 10, 2005 | 11:28 PM
FC3S.USD's Avatar
Where is my Life ?
To use the NA rear drive train with T2 motor you need to :
A) use NA transmision with the recommended clutch combo
B) Use T2 trasnmision and make a custom drivesahft with T2 yoke for NA rear end
C) swao T2 Rear drive train
Old Nov 11, 2005 | 12:55 AM
nik's Avatar
nik
My suggestion to anyone doing a TII swap is to not waste their time with a stock ECU. Just buy a standalone. Anyone who is willing to do a TII swap to get more power will not be happy with just 180HP/200HP a stock TII engine gets you.
Old Nov 11, 2005 | 02:45 AM
hung_lo's Avatar
I have tried a bridge ported carbed 86 fc, and have driven a few turbo'd fc's and I will have to agree with going the turbo route. I am in the process of doing a JDM turbo into my 90 GTU and the wiring is a nightmare. I am not very good with wiring or with anything mechanical for that matter, but hopefully I can get this thing running this weekend. Anyways, I am using a TII trans with custom driveshaft made from a TII input mated to the NA output flange and NA rear-end. I did this to keep costs down.
I'll let you know how things pan out.
