since the n/a's run rich at wot, can I ...
Old Jan 24, 2002 | 01:30 AM
tweaked's Avatar
everyone knows the n/a 7 runns rich at wot right?
WEll I found a "Sneaky Pete" NOS system thathas only like a 10 oz bottle or something. Nos made this for "that extra 110th of a second". It is operated from a 9 volt battery!
any way I was thinking that since these cars run rich at wot I could set this up to only work at wot. that way I could have a hidden advantage over those monster v8's. I know it is cheating but that is why NOS was used in the first place.
What do you guys think? I have already modded the mass air flow sensor to runn a little richer already. so I was thinking that I could run this and get away with it and not have to add extra injectors.
tell me yes!
Old Jan 24, 2002 | 07:16 AM
what is WOT and what do you mean by running rich??
Old Jan 24, 2002 | 07:26 AM
Node's Avatar
WOT = Wide Open Throttle / Full Throttle / Pedal to the Metal
running rich means having a high amount of fuel in your air/fuel.
lean is running with a high amount of air in air/fuel ratio.
Like on a 2 stroke lawnmower (all are 2 stroke i think). You mix too much oil it runs rich and makes thick *** smoke. Mix it too lean it'll run another way.
Node's Avatar
Re: since the n/a's run rich at wot, can I ...
tell me yes!
cheater bottle? hmm nice
Where'd ya find it at?
Old Jan 24, 2002 | 07:47 AM
David88vert's Avatar
r71's daddy
It's not cheating. It's a power booster that is legal. The Sneaky Pete is not a hi-flo bottle. Spend a little more and get a larger bottle. Sneaky Pete is only good for one run.
Old Jan 24, 2002 | 01:01 PM
mazdaspeed7's Avatar
mad scientist
If you need to hide your NOS bottle, you probably shouldnt be unsing it at all.
BTW, Im pretty sure that is a dry system, which increases the fuel pressure by bleeding some NOS to the FPR, which raises the fuel pressure by a lot. This is far from the safest way to put NOS on a rotary. Just get a normal "wet" system if you want NOS, and then you wont have to fill it after every single time you use it.
Old Jan 24, 2002 | 01:26 PM
tweaked's Avatar
I nessessarily want nos. I think I am going to need it for this particular race when it warms up. he claims to have 425 at the wheels. from the parts he told me he had I am thinking more like 350 at the fly. but still he has lots more power than I do. I was just thinking i could get that extra 10th of a second.
Old Jan 24, 2002 | 01:33 PM
von's Avatar
von
hey
If its something that gets you like 10-20 miliseconds faster i wouldnt think it would be harmfull to your engin especially if your running rich up top... But u would have to find out.
Old Jan 24, 2002 | 02:33 PM
Blue Goose's Avatar
You should be alright with the sneaky pete, but don't take my word for law...you can find this system in Jeg's for about $200-225 if I remember correctly, but you really wll wish you spent more for a 10 or 20 pound bottle...what if he want best of 3 runs or some ****? Trust me, it may be safe, but that doesn't make it good...
Old Jan 24, 2002 | 04:17 PM
NZConvertible's Avatar
I'm a boost creep...
A little knowledge is a dangerous thing...
ALL petrol engines run rich at WOT, but NO engine runs rich enough to support nitrous, it'll be instant destuction if you try. You will need to add extra fuel. Dry systems work fine only if you've uprated your injectors to allow for the extra fuel they'll need to supply, otherwise you need a wet system.
Spend your money on a proper setup, it's way cheaper than a new motor.
Old Jan 25, 2002 | 01:59 AM
tweaked's Avatar
true...
I guess I won't do it. I don't really want NOS anyway I like being all motor and still beating people. I just don't know if I can beat this guy. We have both talked alot of **** about the other's car. and there is $500 on the line.
Old Jan 25, 2002 | 02:04 AM
NevadaLoneWolf's Avatar
What does he have anyway?
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
Craze8
11
Aug 14, 2015 06:11 PM
