ABS Pump?
Old Jan 23, 2002 | 08:42 PM
GothicBlade's Avatar
Unhappy ABS Pump?
Allright, here's the situation:
I'll be driving along and the check engine light will come on, and the car wont want to accellerate. Killing the ignition and restarting the car makes the check engine light go away and the car acts totally normal. THe car does this very intermitently, like once a month or so, somtimes a little more often.
Thing is, the mechanic says its the ABS pump (same thing as 'hydraulic unit' in the Haynes manual?) causing this problem, and it needs to be replaced. I dont get it.... can anyone clarify?
Thanks!
-Patrick
Old Jan 23, 2002 | 08:57 PM
No7Yet's Avatar
Uh, your mechanic is full of it.
Seriously, disconnect your negative battery terminal, and tap your brake pedal. That'll reset your ECU, and clear any stored codes it may have. Then drive around until the check engine light comes on. The VERY NEXT chance you get, pull the codes. A quick search of either http://www.fc3s.org or http://www.teamfc3s.org or http://www.130cc.com or even this forum for "pull error codes" or the like should reveal the correct procedure for pulling the error code(s) from your ECU. That'll tell you exactly what's wrong. Get the codes, find out what they mean, and report back to us We'll tell you how to fix whatever's wrong, or at least get you started
...but trust me, your ABS pump will NOT affect engine operation
Brandon
Old Jan 23, 2002 | 09:01 PM
Roger that. I'll bookmark this thread and wait until it happens again, then bump it up.
Just out of curiousity, where does the ABS pump get its hydraulic pressure? The brake pedal/master cylinder?
Also, if its not the ABS pump, what could be causing these symptoms?
Old Jan 23, 2002 | 09:08 PM
No7Yet's Avatar
Well, the ABS pump doesn't "have" pressure, really, it just relieves the pressure in certain parts of the brake system, based on wheel speed sensor inputs.
Make sense?
Brandon
Old Jan 23, 2002 | 09:14 PM
Yes, it does... i mean im familiar with the principles of how an ABS system works, just not the mechanical details.
Any ideas as to what else could be causing it?
Old Jan 23, 2002 | 09:39 PM
No7Yet's Avatar
Well, you neve did say what year/model your car is, so I can't wager a guess
Brandon
Old Jan 23, 2002 | 09:49 PM
'89 TII
Old Jan 23, 2002 | 10:02 PM
No7Yet's Avatar
Hey, mi amigo! A fellow 89 TII'er Is yours Noble White by chance?
Oh, just noticed, that one of my older links should read http://www.1300cc.com , not "130cc". Doh.
Anyway, here're some things it could be...
- bad trailing coil
- AFM
- TPS
- OMP
IMO, the first is the most probable, but why not pull the codes and find out for sure? here's where you need to go...
Brandon
Old Jan 23, 2002 | 10:11 PM
No no... this one is Black. Wish it were white...... a repaint might be in order somwhere down the road.
It just seems to me that all those things would cause a constant problem, not an intermittent one. Oh well, I'll check the engine codes when I get the chance.
Question, first thing I do is reset the ECU, then wait for the problem to occur, right?
Question 2: the infamous 3800RPM hesitation is something that happens all the time, right?
Old Jan 24, 2002 | 12:58 PM
No7Yet's Avatar
1) Yeah, but be read to pull the codes right away Just to be sure...
2) Uh, well, it depends on the car My car has NO 3.8k RPM hesitation (not even a bump on the dyno graph). Oh yeah!
Brandon
Old Jan 24, 2002 | 05:02 PM
Six Rotors's Avatar
Might be your Oil Metering Pump(or wiring)acting up once in a while.When you read out the code though you will know.
Old Jan 24, 2002 | 08:13 PM
Jerk_Racer's Avatar
I don't have anything to add. Just wanted to say hi. I've an '89 T2 as well.
jerk_racer@hotmail.com
Old Jan 24, 2002 | 09:04 PM
No7Yet's Avatar
But is yours Noble White? Mine is...
Brandon
