Ashpault? how to remove?
Old Oct 27, 2005 | 07:27 PM
Wrathritic's Avatar
You know that gravel tar mix these use to patch roads(well at least here), yea well it sprayed up the side of my car anyone know how to remove that?
Yea thx.
Old Oct 27, 2005 | 08:37 PM
Rob XX 7's Avatar
FC guy
try some kerosene
Old Oct 27, 2005 | 09:10 PM
SayNoToPistons's Avatar
Insane Burning Diarrhea
^ id try a body CLay Bar . go to your local auto parts store. they should have some aiavble (clay bar kits. mothers meguiars etc). if you dont know how to use it PLEASE ASK!
btw www.autopia.org detailing professionals lol...(shut up 7_rocket lol)
Old Oct 28, 2005 | 07:41 PM
bajaman's Avatar
Constant threat
Kerosene or gasoline works extremely well.....just be very careful with either of these flammable liquids. I usually take a soft terry-cloth towel and lightly soak a portion of it, then lightly rub against the tar.
Be careful....sometimes there are little tiny bits of the aggregate (gravel) mixed in. If you have a large glop of the crap, this is especially important to watch for.
Old Oct 28, 2005 | 08:58 PM
just try clay bar first, itll take almost any nasty stuff on the paint, no fear of damaging the paint or w/e. but make sure you just throw away the clay bar after ur done since itll pick up all the gravel in it and knead extremely often.
Old Oct 28, 2005 | 09:34 PM
Wargasm's Avatar
Weird Cat Man
the most important thing of all is not to rub the surface.... let the chemicals do the work so that you don't scratch the paint.
I just use "Bug and Tar" remover that you can buy at any autoparts store, but gasoline or pretty much any petroleum-based solvent will probably work just as well.
Soak a small cloth, and apply it to the area and use only the most minimal of rubbing to get the job done.
Old Oct 29, 2005 | 12:32 AM
user 9348703's Avatar
polymide
Old Oct 29, 2005 | 03:20 PM
Rob XX 7's Avatar
FC guy
kerosene is not bad for paint, its the main ingrediant in DuPont's Prep-Sol, I also say that unless there is very little asphault on the car dont rub it in with clay
Erosangel
Sep 18, 2015 04:06 PM
Steelwheelz
Sep 15, 2015 03:22 PM
