74 13b rotor housing help.
Old Oct 19, 2005 | 06:07 PM
kevinbtz's Avatar
Shell 93
I was just wondering if anybody knew any tricks getting the exaust port sleves out on a 74 13b rotor housing. I have loosend the bolts on the bottom, but its still in there good.
thanks for any help,
kevin
Old Oct 19, 2005 | 06:53 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
They're not made to take out. Those "bolts" are the air injector nozzles.
Old Oct 19, 2005 | 06:55 PM
kevinbtz's Avatar
Shell 93
inorder to port the exaust do you have to cut the sleeves out?
Old Oct 19, 2005 | 07:04 PM
Atkins Dan's Avatar
Former Site Sponsor
no!! I port the housing to match the sleve...
Old Oct 19, 2005 | 07:07 PM
kevinbtz's Avatar
Shell 93
cool, thanks
Old Oct 19, 2005 | 07:46 PM
gambone's Avatar
I've done this many times for porting and turbo set ups. There is a roll pin on both sides that go through the housing, you may have to sand down to clean it up a little to find. the real trick is pulling them, find a tap that will match the hole, keep in mind that these are hard pins and you MAY end up braken the tap, so go SLOW with lots of LUB, dont try to tap it all at one shoot, go a little and back off clean lub and go a little more back off and start over and over. find a screw put it in and figger some way of getting a hold of it and pull,
Old Oct 19, 2005 | 07:55 PM
kevinbtz's Avatar
Shell 93
Thanks!!!!!!!!! that was the answer i was looking for!
Old Oct 19, 2005 | 08:01 PM
kevinbtz's Avatar
Shell 93
well, I cant find them... are you sure thats not just on the 86 and up N/A's?
Old Oct 19, 2005 | 08:44 PM
now's Avatar
now
i dont think the old ones have the pins
Old Oct 28, 2005 | 11:42 PM
gambone's Avatar
They all have pins. just clean the carbin off
Old Oct 30, 2005 | 11:21 PM
partly mazda's Avatar
old parts
this is an over 40 question for sure
you can pull the bolts( air nozzles) and cut a little off and weld them shut if you don't need that feature.
just leave the sleeves in and port with them in place.
If i remember right they are pressed in and knurled around the outer ring, I must have pounded one out of a junk housing years ago
john
Old Oct 31, 2005 | 08:54 PM
kevinbtz's Avatar
Shell 93
john
thanks for your help.
Old Nov 2, 2005 | 11:17 PM
gambone's Avatar
Pin
this is where the pins are
Old Nov 2, 2005 | 11:45 PM
kevinbtz's Avatar
Shell 93
74 housing's do not have that pin, that is a 86 and up housing
Old Nov 3, 2005 | 02:01 AM
Jeff20B's Avatar
Lapping = Fapping
It's true that at least some '74 rotor housings did not have roll pins. I have a set that didn't have them.
Old Nov 3, 2005 | 11:50 PM
stilettoman's Avatar
No, it is not stock!
Dfwi
Just weld up the air injector holes or drive in a plug. I know people who used to do it with a high strength epoxy.
Inless you are building a LeMans racer, there is no benefit to removing the sleeves. Just port to the approximate shape of the sleeve, as someone has suggested. You will be producing one hell of a lot of horsepower before the exhaust is the limiting factor. You can vary the size and shape of the OPENING into the rotor housing, which controls the timing (and the NOISE). Independently of this, you can vary the size and shape of the FLOW PATH through the housing.
The main effect of making the port larger will be to make the engine a lot louder. I have done a few, and I have one with overly large exhaust ports. My exhaust guy gave up after several tries, and could not find a way to quiet it down without killing the power. Surprisingly, it runs fine. The large exhaust ports make it idle like a street rod with a radical cam, but the driveability and gas mileage don't seem to be much affected.
Ciclovnz
Oct 18, 2015 03:04 PM
cdn
14
Sep 10, 2015 06:23 AM
VTECthis
Aug 24, 2015 09:01 PM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
