Sponsored by: CARiD
GSL-SE Compression
Old Oct 6, 2005 | 02:27 PM
cptpain's Avatar
Torqueless Wonder
GSL-SE Compression
i am looking at a GSL-SE for sale. i have the money and looks good but before i give the guy the money i want to test the compression. one of my mechanic friends has the compression tester tool and is coming with me to check the car out one final time. i was wondering what is an acceptable compression for a 13B with 138k miles on it. cause if its not to a acceptable level i wont buy it. thanx.
Old Oct 7, 2005 | 11:57 AM
cptpain's Avatar
Torqueless Wonder
its an 85 GSL-SE by the way
Old Oct 7, 2005 | 05:16 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Anything above 95psi on all faces and about a 5psi difference between them.
Higher is all was better
Be sure to pull the one way valve on the compression tester so you get each rotor faces pressure and no the over all pressure.
Hope this helps
turbodreamz22
28
Nov 10, 2023 11:08 AM
Andrew7dg
Aug 6, 2017 01:41 PM
