10 sec.
Old Oct 3, 2005 | 06:45 AM
blink's Avatar
Newbie
Question 10 sec.
new owner of 1993 R1, which turbo can provide enough boost for street racing in terms of a 10 sec. quarter as well as a topping of around 150/160 mph.
Old Oct 3, 2005 | 08:39 AM
dubulup's Avatar
development
I'd recommend the F&F200R
Old Oct 3, 2005 | 10:58 PM
BlackTurbo2's Avatar
no, they have a new one out...way more power, the F&F3x. Its got some cool LED's on the compressor housing too! =o)
All joking aside blink, you are aware that you can't just throw a BIG *** Turbo on and run 10's right?
A good start would be to do some research, and make sure your car is in good working order as stock before you start throwing parts at it.
Old Oct 3, 2005 | 11:09 PM
eriksseven's Avatar
Make Money.
My TII with a DP/MP and a couple other basic mods (stock turbo etc.) went up to 150 before I let off... So, I'd assume your FD would be able to do it (although I would in NO WAY recommend going that fast).
To run 10's you'll need a large aluminum wing at least...
Old Oct 3, 2005 | 11:21 PM
209FD's Avatar
4 year FD *****
You car will go 150/160+ stock, but before you want to hit 10s take advantage of the forum and do your research. And if your looking for 10s you better have deep pockets, around $8k+ deep
Old Oct 4, 2005 | 02:40 PM
purerx7's Avatar
Registered User
$8k is a little bit on the low side, if done properly i would say ATLEAST 12k, which would include a rebuild and full street port.
Old Oct 11, 2005 | 06:17 PM
Bluem's Avatar
Concept Motorsports
dont forget the motec system exhast! lol!
Old Oct 12, 2005 | 02:09 AM
full-cruise's Avatar
D.I.L.U.S.I.
lol 10's on just turbo.. wouldnt that b nice.. big bills bra but please do it. i luv hearing about guys making it into the low numbers... good luck with your car and do alot of reading around here.
Old Oct 12, 2005 | 11:35 AM
cripsR6's Avatar
11.7@128
The stock twins have, at least in one case, proven to be good enough for a 10 second timeslip. I think that most single turbos available can also provide the power you need to make a 10 second pass providing there is enough fuel, some type of aftermarket engine management, good tires, as well as a decent boost level and an adequate driver. Oh yeah, and about 14 grand wouldn't hurt either.
Old Oct 13, 2005 | 06:11 PM
Bluem's Avatar
Concept Motorsports
theres a car here runing 10.97 on stock twins, 4.77 final ratio, slicks, runing on a microtech ecu, and light weight every part on the car!
Old Oct 14, 2005 | 08:45 AM
turboR1's Avatar
ErnieTKiLLA
all u need is 450rwhp and a good driver.. and you got a 10 sec pass..
Old Oct 14, 2005 | 07:27 PM
tonyttt's Avatar
i have a tec3r that i am selling and my turbo set up just go to www.ispracing.com click on pic and you will see my set up . i went 9.97 at 30psi and the turbo wanted more . this is one of rotor dee's set up 600whp no problem at 25psi also selling set of 1600 850 1000 cc injectors motor and more .
Old Oct 15, 2005 | 04:16 PM
SkylarNeedsParts's Avatar
my car is always broke **P
you dont even need that much if you have a good driver and some good tires. my friend has a time slip in the mid 11s with 350 whp on the efini twins. you should be able to hit tens with 400 or so and most singles can net that much on race gas at reasonable boost(i.e. 15 psi or so)
oh i just read hes talking about street racing...dunno anything about that :/
Old Oct 20, 2005 | 07:26 PM
fastrx7man's Avatar
Looking for 10's
I went 11.7 on my old twin setup...only making 332rwhp and went 11.1 when single making 406rwhp. I would have eventually made it into the 10's with that setup. I trapped 126mph going only 11.3. My 11.1 pass was at 121mph. I think with the right driver it would only take about 400 to the wheels to go in the 10's.
Give me about a month and I am hoping to make that 10 second pass with only 400rwhp.
qqqqball
11
Oct 9, 2015 07:06 PM
bryancmatthews
Power FC Forum
Sep 5, 2015 03:57 PM
Michael Filippello
Power FC Forum
19
Apr 22, 2002 09:42 PM
flubyux2
Mar 23, 2002 07:46 AM
Anton
Jan 15, 2002 08:40 AM
