Power FC PowerFC safe/limp mode reset?
Old Sep 29, 2005 | 08:13 PM
FDHayce's Avatar
Is there a safe/limp mode in the PFC? If so how do you reset it without losing tuning info?
As soon as the car sees boost it kills the ignition timing to zero.
Unfortunatly the car is a boosted honda but im hoping this is a generic PFC function... I posted here as its a dedicated PFC forum. Dont slap me too hard please. Ive tried honda places but no joy.
Any help appreciated.
Old Sep 30, 2005 | 12:07 AM
rynberg's Avatar
The PFC does NOT have a limp home or safe mode, at least not on the RX-7 version.
Perhaps your PIM scale is way off.
Old Sep 30, 2005 | 12:26 AM
FDHayce's Avatar
Just found there was no limp/safe mode and yup it was the pimm screen.. it was set to "option 3" should have been "normal" funny though all the values are the same in all options...
Thanks rynberg
Old Sep 30, 2005 | 07:52 PM
cewrx7r1's Avatar
Eye In The Sky
Only the "NORMAL" map works for our stock cars unless a setup for a 3 bar or something else is done under one of the OPTIONS. When you go into one of the optional ones and come out, it turns it on. But since it does not work, the PFC goes into limp home mode just as if the map sensor was bad or disconnected.
You then have to go back into normal and out of it to turn it back on.
YES it has a limp home mode.
Old Oct 1, 2005 | 12:57 AM
FDHayce's Avatar
So it does have a limp/safe mode of sorts... thanks for the options explanation this must be what I did stupid **** me.
Old Oct 1, 2005 | 08:42 AM
cewrx7r1's Avatar
Eye In The Sky
Many of us did the same thing when the PFC came out in 1999.
Old Oct 1, 2005 | 05:27 PM
rynberg's Avatar
Wow, I was not aware of that, Chuck. Thanks for the correction.
24seven_dada
20
Nov 10, 2018 12:03 PM
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
