estimate my trap speed in 1/4.
Old Sep 27, 2005 | 04:26 PM
TwinTurbo_SE7EN's Avatar
resU deretsigeR
I raced a 2002 Z06 with heads/cam/all bolt-ons that trapped 123 mph in the 1/4. we went from 40 mph to ~140. I was ~ 1.5-2 cars back when we let out. How fast do you think my car will trap in the 1/4?
Thanks.
Old Sep 27, 2005 | 07:14 PM
neit_jnf's Avatar
sounds like a school problem hahahaha
A VERY ROUGH ESTIMATE:
if our cars are 12 ft long and you were 2 behind it means you were 24 ft behind
so in 100mph difference (140-40) you lost 24 ft
100mph = 147 ft/s 140mph = 205 ft/s
205-147 = 58 ft/s
my brain hurts... I need either the total distance travelled or the time it took you or both to complete the calculations hehe
but by the time you were going 140 he was already past 140... i give up
you'll trap 115, there it was way faster that way hahah
Old Sep 28, 2005 | 08:16 PM
r0gu3's Avatar
Boostless FD
Two car lengths makes 8 mph difference?
Old Sep 29, 2005 | 07:22 AM
neit_jnf's Avatar
I don't know I just said 115 because I didn't want to keep on calculating
but if by 140 they're *only* 2 car lenghts apart I would guess they're not too far in the 1/4 mile
Old Sep 29, 2005 | 10:46 AM
2FAST7S's Avatar
Can you drive? lol
Have you had your car dyno'ed??? Generally if you make 300 youre trapping around 110, 350 is about 115...
go to the drag strip and find out! As it is we're just guessing.
Old Oct 6, 2005 | 10:25 PM
resU deretsigeR
353 rwhp. and I am a decent driver. I trapped 108 with 251 rwhp or less since the 251 was on a base pull at 14 psi and my previous 108 MPH trap was at 10 psi.
Old Oct 7, 2005 | 07:45 AM
neit_jnf's Avatar
something just doesn't make sense... if you dynoed 251whp at 14 psi there's something wrong with your car
now 251whp at 10 psi is believable but at that power level the car won't trap 108
I was trapping 107-108mph at 315whp at 13.5 psi now I'm trapping 110mph with a metal core high flow cat at the same boost. I wonder what my power is, I'm guessing 320-325whp
Old Oct 7, 2005 | 10:40 AM
resU deretsigeR
started out at 251 rwhp on the dyno (A/F in the high 8s)...finished tuning with 353 rwhp at 14 psi (A/F in the low 10s). boost was set to 14 psi that morning. so Im assuming that the power it made would be less at 10 psi for the run at the track with a 108 trap speed, boost was at 10 psi and Im assuming it couldnt have been making more than 250 at the time.
Old Oct 10, 2005 | 10:14 AM
matty's Avatar
Originally Posted by 2FAST7S
Can you drive? lol
exactly.
Old Dec 13, 2005 | 08:06 PM
Outkast's Avatar
Mr. Goodwrench
I trap 114 on 330 rwhp and 124 on 410 rwhp
Old Jan 4, 2006 | 05:04 PM
ForceFed's Avatar
You can't possibly be serious? Either that or you could just be the world's worst driver
My stock FD trapped 84mph in the 1/8th mi and 107 in the 1/4mi and all I had was silicone vac hoses, RB springs and Tokico 5-ways, LOL! Try practicing your 1-2 and 2-3 shifts and you will be amazed at how much speed you'll pick up in the 1320.
Old Jan 4, 2006 | 06:02 PM
neit_jnf's Avatar
I consistently trap 109~110 pass after pass with et's between 12.8 and 13.1 on street tires and kinda worn clutch (original with 45k miles)
I'm not the best driver but at least it's consistent...
maybe better tires and a new clutch is what I need?
Old Jan 5, 2006 | 07:18 AM
matty's Avatar
i think your stock trap speed is high. i dont think its that it really represents what stock fd's can do. From what i have read it seems that most cars trap 100mph plus or minus a few.
Old Jan 5, 2006 | 07:09 PM
ForceFed's Avatar
I won't dispute that. The problem is that most stock FDs aren't running nearly as healthy as they should and unfortunately most owners don't have anything to compare them to. I didn't either. I thought my FD was a factory freak when it ran 13.5s@104-105 when I still lived in upstate NY. Then I got down here to Charlotte, raced an all motor Maxima from a roll and lost. Then I noticed it wasn't making full boost on the secondary in 2nd gear. So I replaced the vac hoses with silicon ones and apparently got all my lost power back and the difference in power was shocking. A stock FD running 100% has the potential to be a very quick car considering its age.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
WyomingTII
Sep 28, 2015 10:32 AM
