12 a stereo
Old Sep 26, 2005 | 12:35 AM
riceburner1r2001's Avatar
Talking 12 a stereo
i have a 85 12a stock stereo and the guy who had it before me messed up the radio wires and want to know if the 85 gsl-se wires are the same in the back and if not can someone give me a pic of it ..
Old Sep 26, 2005 | 06:08 PM
bump
Old Sep 27, 2005 | 05:25 AM
15 people have looked in here but dont no.. come on
Old Sep 28, 2005 | 01:59 AM
HOZZMANRX7's Avatar
Driving RX7's since 1979
The only real difference between the GSL-SE sterio and 12A type sterio
Is the joystick control as far as I can tell. But, you best bet to determine compatibility is to go to the iluvmyrx7.com web site and look at the pdf 1st gen factory manuals for the electical schematics.
Alternative, if you are available this weekend so I can get those parts I need, I'll bring my 85 factory manual with me. Let me know via PM.
Old Sep 28, 2005 | 02:06 AM
TurboIIGuy's Avatar
Driveline Killer
hmmm.
I have an SE parked outside and I have a 12a gsl in the garage...
I can check if you haven't found out yet.
I know the SE and GSL had amplifiers. So there might be a difference.
Why not just go with an Aftermarket radio and simplifiy things a bit???
Old Sep 28, 2005 | 05:45 AM
cuz its my bosses car and all i want to do is fix it. and i think it might be sunday u can come over hozzman
Old Sep 29, 2005 | 06:16 AM
bump de
Old Oct 1, 2005 | 02:35 AM
bump de de
Old Oct 1, 2005 | 08:42 AM
TurboIIGuy's Avatar
Driveline Killer
okay I checked the GSL-se radio and the non SE radio yesterday and they are the same plugs.
The joystick fader that the GSL-se has in the center console just in front of the arm rest is still wired up in the non SE but instead of a joystick there is just a wire connector that bypasses it.
As for the amplifiers that are in the SE, it doesn't make a difference. When the car is on so are the amplifiers. They are not turned on by the radio as aftermarket amps are that turn on and off with the radio.
So yes they should be interchangeable as mine show to be.
Hope this helps you out.
Good luck
Old Oct 3, 2005 | 03:48 AM
ty turboii guy for your help i will be checking today
TeamRuffRacing
Sep 30, 2015 08:13 PM
betes
Sep 27, 2015 08:25 AM
Captain Hook
Sep 22, 2015 01:12 PM
