Autronic Forum Area is for discussing Autronic EMS
Autronic Ordered an SM4 and 500R.
Old Sep 9, 2005 | 04:29 PM
a7r's Avatar
a7r
I broke down an ordered the hardware today. I'm planning on running 4 independent coils, possibly coil-on-plug. My distributor is recommending that I go with a modified CAS (2 triggers, 1 sync), what are you guys running?
Old Sep 9, 2005 | 11:15 PM
Bad2ndgen's Avatar
Will it be running a trigger at 0 and at 180? Get ahold of frobe on here, I believe he is running an unmodified cas s4/s5 with sm4... You may be able to get a base cal from him to see how he set up the triggers.
Old Sep 10, 2005 | 04:16 AM
frode's Avatar
We are running a 13B PP with stock unmodified S4/S5 cas and SM-4, 500R and 4 coils. I will get hold of the cal file and help you out (setup was a little strange).
Regards,
Frode
Old Sep 10, 2005 | 02:12 PM
a7r's Avatar
a7r
Excellent, thanks.
My support contact told me that the reason he wants me to only run 2 triggers at 0 and 180, has to do with the fact that the SM4 samples MAP on the trigger points (I obviously don't have the SM4 firmware's source in front of me, so I can't verify this). As I understood it, his opinion was that having more triggers than 'cylinders' doesn't give the SM4 the best MAP reading.
Old Sep 13, 2005 | 07:46 AM
enzo250's Avatar
IRS Champion
you can use the stock cas unmodified. Stock cas is magnetic.
Most guys like using hall effect, including myself. Whenever possible i build my own triggers using hall effect sensors since they are much more reliable and accurate.
Old Sep 13, 2005 | 07:49 AM
enzo250's Avatar
IRS Champion
Originally Posted by a7r
Excellent, thanks.
That's if you were building a sensor off the crankshaft. If using the CAS it spins at half speed so you will need 4 teeth at 0, 90, 180, 270
Old Sep 13, 2005 | 12:17 PM
a7r's Avatar
a7r
Yah, I should have made it more clear, two triggers per engine revolution (i.e. 4 CAS teeth). I've been looking at the setup some local rotary guys have been using with their TEC 2 units (i.e. 60-2), and it wouldn't be that bad to setup something similar (with a different trigger wheel).
enzo250, whose hall effect sensors do you use? Cherry?
Old Sep 13, 2005 | 07:57 PM
enzo250's Avatar
IRS Champion
i use honeywell...
Old Sep 13, 2005 | 07:58 PM
enzo250's Avatar
IRS Champion
what do you plan to do with this car? Is it an all out race car?
Or just daily driver/semi race car. You should be fine with stock cas unmodified.
Old Sep 13, 2005 | 09:38 PM
frode's Avatar
We have never had any problems with using the stock cas and reluctor interface.
Old Sep 13, 2005 | 09:54 PM
a7r's Avatar
a7r
This car is a stripped-down canyonr-runner, that I mess around with. If I went hall, it'd be because I think it's cool, not because I need it.
frode, regarding the stock CAS, that's great. What settings do you use for the 12/1 tooth configuration?
Old Sep 14, 2005 | 12:54 AM
Bad2ndgen's Avatar
I am such an idiot, until now I didn't realize that the cas spins at half speed! And on that note I think you can set it up like this...
12 cylinder 2 stroke, four coil firing at 0,0,180,180 for ignition base angles, 0,180,0,180 for fuel base angles. Don't mind the ERROR warning in the startup screen...
You can use coil 2 and 4's ign trims to set up your split timing based on load and rpm's!
Wiring is pretty strait forward, Autronic is rad...
NickNac113
13
Oct 1, 2015 09:25 PM
